What is this piece of metal in my hydraulic filter?
MD2595
M7060HDC12
Jul 5, 2021
17
East Texas
My M7060HDC12 has 432 hours and I blew a hydraulic hose (cheap factory Gates) and since my tractor is almost 500 hours, I went ahead and did a hydraulic fluid/filter replacement.
When I took off one of the filters, this piece of metal was stuck to one of the magnets.
It kind of looks like a tooth off a ring gear.
What do y'all think?
7,906
That's a gear tooth.
Doesn't look like a diff gear tooth, it's straight cut, it's more likely a transmission gear tooth.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,272
1,467
Near Lancaster, PA, USA
My guess is Wolfman will be able to tell you which gear its from.
7,906
There are quite a few choices of which gear exactly if it is indeed a straight cut gear.
Another possible but very odd place, it could be a hydraulic pump gear tooth.
That would be your best scenario, as it would be an easy and cheaper fix.
Clean it up and take a couple more pics.
Some of the choices:
7,906
One other thing comes to mind, is it possible that some used hydraulic fluid was added at anytime in it's life.
Or was it in for repairs anytime in it's life?
2,824
Anytime I've worked on a piece of equipment with a broken gear tooth, I have been able to hear a click or change of tone when the broken spot was rotated against it's mating gear.
(especially with straight cut gears)
It has to be a quiet area, wheels jacked up, and use a stethoscope or screwdriver handle in your ear.
Might let you narrow the location down.
Orange man
Kubota L2501 LA525 loader , woods prd6000 mower, Land pride RB 1672
Jul 23, 2014
210
122
WNY
I hope it is still under warranty. Looks like it could be an expensive fix.
3,010
1,467
The most probable is from gear #70 on the bevel gear parts page; I believe that is the one the park pawl contacts.
5,452
Concerned for sure ! HOW did the tooth break off is the $$$ question ! Gears that are in constant mesh(ie do NOT move laterally) are unlikely to break.Gear pump gears seldom 'break' in use, more likely bad steel or machining ). Gears that do move( say 'transmission gears' can break when shifted while in motion( or the shaft they're on is still turning).
Only way to know for sure is to inspect EVERY gear inside. Maybe a borescope will work ? I'd buy and try before committing to a TOTAL TEARDOWN
