What kind of fuel cans / fueling systems are folks using?
Old Machinist
May 27, 2024
211
217
NE FL
I have a 100 gallon aluminum tank off a Freightliner truck. I can't remember what I paid for it at a salvage yard. I use a 12V pump, hose, and nozzle off eBay that was about $65 and I upgraded the nozzle to an auto shut off model for another $30 ish. I have a solar panel on the roof connected to a charge controller and a deep cycle battery to power it. I also have some LED lights and a Wyze cam connected to it.
7,878
What did you use on the tank for the fittings for the sight gauge. I have a meter on mine and a spreadsheet that I keep track of how much I put in and take out. I also use the spreadsheet to tell me how much weight is in the tank so I can figure how much fuel I can add when I take it to the station to "fill" it. The L3901DT won't pick it up if I fill it.
Wait, what?
You can't pick up 50 gallons of fuel with your L3901????
I can pick up 250 gallons with my l3450 and it's smaller than your tractor.
7,878
Super set up, just watch the PVC parts as the diesel on the inside and sun on the outside will make them brittle over time.
Old Machinist
May 27, 2024
211
217
NE FL
It's in the middle of a barn with 3 sides enclosed so no direct sunlight on the PVC. I think worse case if it gets brittle and breaks it will just fall on the ground letting me know I need to replace it.
