Committed the ultimate sin.
1,577
Actually it will not work!
The return and the supply will both get the same pressure as they are both in the tank!
Simply remove the small vent line (YELLOW) off of the jet start valve (RED) on the side of the injection pump and crank if fuel comes out then the injection pump has fuel to it.
It will work! (at least on my L185). IF you open the bleeder valve at the pump. That ”disconnects” the pressure loop that you point out.
I had not thought about that double ended pressure loop though. Thank you for mentioning it.
7,867
Yes on your L185 it works because that bleeder vents to the open air, where the bleeder on newer tractors like this bleed back to the tank.
7,867
That's odd. I have changed the fuel filter on probably 40+ of the 60-series tractors and have never had a problem.
I'm pretty sure you are under exaggerating how my fuel filters you've messed with! 😜
I couldn't even guess at the number of filters I've messed with and I'm nowhere near the tech you are!
3,007
1,464
Three of us easily fill a 55-gallon barrel in less than 2 weeks, oil and spin on fuel filters.:cool:
