L4240HSTC-3 Turbo upfit-upgrade?
dfixit1
L4240HSTC-3
May 17, 2019
143
United States
Wondering if anyone has performed a turbo upfit-upgrade on one of these?
I think the boost would come in handy with my front snowblower on my hilly driveway. It is a interim tier 4 without the catalytic converter and dpmf.
Thanks
tractorX
KUBOTA L2501 DT 5' BOX BLADE 42" FORKS PIRANHA TB 5' BUSH HOG 6' GRADER
Sep 27, 2013
82
82
Rock Spring GA.
Rdrcr
Vendor Member
May 7, 2021
722
829
WA
Thanks
I’m not familiar with your tractor or engine. Is it a simple mechanical diesel or is it electronic computer controlled? If mechanical, a turbo can be added without too much trouble. If electronic, as of this posting, I’m unaware of anyone offering ECM ‘tunes’ that would be necessary to control fuel for that setup.
Mike
8,359
Yes you can bolt a turbo on it, but you'll need to rework the fuel injection pump to get anything out of it.
5280GearHead
L3240 HSTC Grand L, L514, Chipper, Grapple
Oct 15, 2024
Denver, Co
Hello, new to the forum here. Looking for some suggestions and guidance to add hp/air to my victim which is a 2012 L3240 HSTC-3 (D1703) 770hrs. my issue is the property sits at 8700 ft elevation where the air is a little thin. Im not looking to do hole shot wheel stands, but a reliable boost of AIR into my orange breathing dragon would be great. Anyone out there make a reliable, proven turbo kit for a D1703, (non dpf, mechanical Diesel)? I read in past years where Mikemoto on this forum had built a turbo kit with an oem RH3F Kubota turbocharger setup on his D1703. Any help to get my Orange Angry Dragon breathing at altitude would be GREAT. <Les>
Rdrcr
Vendor Member
May 7, 2021
722
829
WA
Can you take some more pictures of your engine/engine bay? The S2T Performance L2501 Turbo Kit may fit your L3240.
The L2501 Turbo Kit is currently on Back-Order but, is well worth the wait!
Mike
5280GearHead
Oct 15, 2024
Denver, Co
Mike,
Thanks for the suggestion, I’ve been researching the S2T performance L2501 kit and the L3240 is basically identical. Where it gets interesting is getting the compressor pipe over top of the AC Compressor, who put that ac compressor right in the middle anyways 😎.
I think I’m going go ahead get on the back order list. If all goes well by spring the Orange Angry Dragon will have a new attitude and some extra air in her lungs. Thanks again Mike
5280GearHead
Oct 15, 2024
Denver, Co
Happy St Patty’s Day.
Just received my L2501 Turbo Kit, soon to be slightly modified for the L3240 Orange Dragon.
8,341
Awesome! Looking forward to seeing the kit installed. Hope you report back with performance and photos.
5280GearHead
Oct 15, 2024
Denver, Co
Absolutely, I will certainly report back with the mod’s needed with photo. The boys at S2T Performance have been great in helping me spearhead this new application as well.
Rdrcr
Vendor Member
May 7, 2021
722
829
WA
That’s a good looking Turbo Kit!
I think I recognize that one! :D
We’re really looking forward to your install and are interested in the modifications that will be required to make the L2501 Turbo Kit work on your application. We have several other L3240 owners interested in your progress as well.
We’ll definitely be following your thread and as always, please reach out to us if you need any assistance.
Mike
5280GearHead
Oct 15, 2024
Denver, Co
Mike
Mike
[/QUOTE
Mike
Hello fellow Gearheads and you to Mike,
The day has finally came, The Orange Dragon is currently under the knife getting a well needed boost under its skirt. After all’s done and fat lady has sang, our hope is to have ourselves an Anger Orange Dragon.
Once the job is complete, I’ll have the details of what I had to be modified to fit the L2501 on the L3240 HSTC-3 with AC compressor in the way. Here are a few preliminary photos for us visual ones to poke fun at.
1. The coolant overflow tank is easily moved below the air box. IMG_7440.jpeg
2. A slight message to the fuel tank heat shield at the turbos exhaust 90*. IMG_7432.jpeg
3. Another slight exhaust tube message over the alternator bracket. IMG_7433.jpeg
4. About 6” of tube added to the compressor intake tube to get over top the AC compressor. IMG_7446.jpeg
8,341
Wow! Not sure what I envy more, your shop or your turbo installation. Well done to @Rdrcr and you. Really looking forward to hearing your impressions of the improved performance. (y) I went at the problem from the other end but am very pleased with where I ended up.
Rdrcr
Vendor Member
May 7, 2021
722
829
WA
Looks fantastic! You’ve been busy! Man, looks great!
Thanks for posting pictures!
…and yes, your shop is awesome!
I’m definitely looking forward to your impressions once you get everything finished.
Once again, great work!
Mike
5280GearHead
Oct 15, 2024
Denver, Co
Good morning fellow Gearheads,
Well got the Orange Angry Dragon up to 8700ft of elevation for some testing. Well, right out of the gate I experienced the same Damb power loss, same engine surge just with a lot more power from the turbo kit :(. After a few colorful words and a conversation with myself. I found the fuel pump was at fault and was not assisting the injection pump at power demands, new pump fixed the issue.
Ok, now we are getting somewhere. With a 540pto engaged, 4psi boost, 600egt at 1 1/2 turns out on the Inj pump the performance is now unhinged to say the least, but I feel I can certainly add more power which I will do with the turn of an Allen key. The Kubota is Absolutely feeling the Turbo love connection.
Rdrcr
Vendor Member
May 7, 2021
722
829
WA
Great to hear!
The Turbo Kit provides a massive amount of power. You’re not even breaking a sweat yet….wait until to get a real load on that beast…you have TONS of power in reserve.
Mike
Rdrcr
Vendor Member
May 7, 2021
722
829
WA
I would like to express a big thank you to @5280GearHead for taking the leap of faith and purchasing the S2T Performance Turbo Kit. We also thank him for making the modifications required for fitment, supplying pictures and of course, his feedback on the Turbo Kit and the performance improvements.
We’re extremely fortunate that we have another L3240 being delivered to us for a Turbo system very soon. Therefore, we will indeed have a Bolt-on Turbo Kit for the Grand L40 series L3240 tractor. And, that owner has agreed to a PTO dyno session so we’ll also have power numbers for this model.
We’re really excited about this new Turbo kit!
Mike
5280GearHead
Oct 15, 2024
Denver, Co
Mike,
That’s great news regarding another Grand L3240 project coming your way. I’m extremely pleased with the drive performance and the PTO power is exceptionally impressive, even at 8700ft elevation. I haven’t had a chance to turn up the injection pump yet, but in a few weeks I’ll give the Orange Dragons injection pump an extra turn out some more attitude. If you have any questions feel free to reach out
