I might have caused some confusion here so my apologies.
I referred to the multiplier that
@JasonW installed as a diverter but that's really because of the way I'll be using the same multiplier. I have the four button Control Grip with momentary buttons which are pressed with the thumb while moving the in cab lever forwards or backwards. In my case only one function is activated at a time i.e. either extending or retracting one piston in one cylinder as the lever is moved while a button is pressed, so diverting oil for that one function. In
@JasonW's case, he could extend or retract the piston on as many as one to four cylinders simultaneously by energizing one, two, three or four solenoids, so basically multiplying the output.
From Summit Hydraulics.
"A hydraulic multiplier is a hydraulic diverter selector valve that allows you to easily add additional rear remotes to your tractor. Keep in mind that
this isn’t a hydraulic control valve. This means the hydraulic multiplier
does not control the fluid in and out of a cylinder (see our
manual monoblock or
solenoid monoblock valves), only what cylinders will receive the fluid from a control valve already installed.
The switch box control features
4 separate rocker switches which allow you to select circuits 1, 2, 3 or 4
separately or simultaneously. The anodized mounting bracket is fully protected against corrosion and offers quick and easy installation, the industrial-grade enclosure and switch are weatherproofed for durability. A
10ft wiring harness with weatherproof connectors is also included."
