How to repair a cut in R4 Tire Tread ???
Arausio
L2501, LA525, BH77
Oct 20, 2021
WI
Hello all -
My R4 tire has a slice cut in the tread - the tire itself is fine. I tried to glue the tread flap using
Xtra-Seal Chemical Vulcanizing Cement (8 oz.)
but it did not hold - and yes the joint was thoroughly cleaned before the vulcanizing cement was applied. Any suggestions would be appreciated. Thanks much.
5,434
curious, dld the instructions...
appears to be a 'contact' type cement so it HAS to be DRY before parts are joined.
According to the sheet can take up to 5 minutes based on temperature and humdidity levels....
maybe try again
clean/buff,apply but use toothpicks to keeps parts from each other for at LEAST 5 minutes then remove toothpick, press together hard and hold.
OntheRidge
Nov 1, 2020
367
427
I think I'd just let it be, doesn't look too serious.
Reactions: 6 users
7,691
My suggestion, and the hard honest truth, just forget about it.
Your not going to fix it where it will actually hold!
You've now got a used tire.
5,434
Curious so please explain why ?
The screw only goes into the 'LUG' ,horizontally, has NOTHING to do with the air inside or structural integrity of the tire/rim. The extra weight 'might' affect performance ??
7,691
There are too many reasons to write them all up!
je1279
Dec 6, 2020
826
578
Upstate NY
I agree that the tread cut appears to be minor and not something that will ultimately compromise your tire. If it bothers you, clean out the sliced area and apply an adhesive you feel will do the job. In the event that it fails down the road, shrug it off and continue to tractor on.
4,423
Looks like normal wear & tear to me. Whether it eventually chunks out or stays like it is, it’s irrelevant to performance.
armylifer
Mar 26, 2013
2,074
807
Thurston County, WA
I would just cut that little piece off with a sharp knife so it would not continue to tear off more tread. Cutting it off would prevent the torn piece from continuing to tear off more rubber in an unpredictable manner.
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,464
1,910
Western MT
I agree with cut it off (it looks small), so you can control how the tear continues.
If you don't want to do that, clean it really well with isopropyl alcohol or sand/shave it slightly . Then, use the vulcanizing cement, but leave it under pressure for a day or so in a warm location.
airbiscuit
Mar 18, 2021
275
251
NW WI
I would just trim it.
This stuff is interesting though
KKBL
Jan 5, 2022
119
129
Girard, PA
I would just trim off the flap to avoid additional tearing as others have suggested. Save the flap as a reminder that you have used your tractor for actual work.:)
