Rear Hydraulics
JasonW
383
191
Al
Needing some input/guidance on rear hydraulics if there is anything I may be overlooking.
I currently have one rear remote on my M6040 that I use with a hydraulic top link.
I just purchased a rear blade with hydraulic tilt and angle adjustments. Also purchased a box blade with hydraulic scarifiers.
So either way I will need more rear remotes. Dealer I purchased the rear blade from said each additional remote was $1,500 for my tractor. I can stack up to three on my model. Will definitely be shopping around price wise if I go this route.
Would I be better off adding two additional factory remotes or going with a hydraulic multiplier running off my current remote? Looking at the Summit hydraulic multiplier kits.
What other implements are there that would need multiple remotes that wouldn’t work with just a hydraulic multiplier?
MtnViewRanch
853
293
Lakeside Ca.
Even if you spend the money for the factory valves, you still may end up needing a multiplier anyway.
A good chance that before your done you will add a hydraulic side link for the 3pt hitch for box blade use as well as an offset cylinder for the rear blade.
A multiplier is without a doubt the cleanest least costly way to get more sets of couplers to use.
Get a control grip for your rear control lever that has all the switches in it. That way you have full control of all the hydraulic outlets without ever moving your hand back and forth changing switches.
I have added 3 diverters to my smaller tractor for a total of 4 sets of couplers and 2 diverters to my larger tractor for a total of 5 sets of couplers.
When you start using hydraulics to make adjustments, you can never have enough. ;)
wsurff
L6060, Backhoe, Front Snow Blower, Grapple, Chipper, Box Blade
Oct 8, 2021
41
25
NJ
I have a Summit 2x multiplier on my L6060. Works well. Sounds like you may need a 3x multiplier for your needs.
JasonW
383
191
Al
Yes I’m leaning towards the summit 4 circuit multiplier. Just didn’t want to have to buy twice if it will not work some implements that I don’t know I have to have yet.
MtnViewRanch
853
293
Lakeside Ca.
A multiplier will work any implement that your existing control valve works. The only difference is unless you get maintained switches (not recommended for a control grip) you might as well forget about the self-cancelling portion of your current valve.
To emphasize, they will work for any purpose that the existing valve & couplers will connect to. The only difference is if you have maintained or momentary switches. You would need a maintained switch to take advantage of the self-canceling feature of your current control valve.
JasonW
383
191
Al
Yes I Believe the factory valve is self canceling detent. I’ve used a pull type disc and I believe that feature worked then but it doesn’t work with my hydraulic top link.
I believe the summit setup uses maintained switches, although if I go with their kit I might use different switches depending how big their switch box is.
JohnDB
M4500DT
Jun 9, 2018
419
74
NZ
I've never used a hydraulic multiplier so perhaps MtnViewRanch and wsurff can put me right here: if you need to actuate different cylinders - for example adjusting the tilt and angle on your rear blade while operating - I got the impression that it takes extra actions (switching the multiplier between cylinders, then operating the spool valve) to do that compared to having a spool valve for each (or even better, a joystick for the both)?
Yes cost may be a disadvantage, and maybe there are circuit or space limitations on your options too (don't know your model of tractor), but would useability be a consideration?
7,997
@MtnViewRanch was helpful with my understanding of how these diverters work which to me is a better description than multiplier. You're correct that you have to energize a solenoid on the diverter in order to open up that circuit so that you can adjust the cylinder on that circuit.
Based on @MtnViewRanch's recommendation I ordered an X Series control grip from Scorpion with four buttons that attaches to one of the rear remote control levers in the cab. The buttons are momentary so you push a button and move the lever to activate the cylinder associated with the solenoid controlled by that particular button.
7,997
I have three sets or rear remotes on both tractors, but ideally would have four. One of the three remotes in the MX is a float detent (FD) and two in the M6060 are float detent type (FD). If you plan on running any equipment that needs float then you'll need to add another rear remote. I use float when running the folding cutter, the flail and the snow blower.
The Scorpion control grips are probably the nicest way to add control of multiple circuits although the switch box that ships with the Summit kits looks decent, just not as ergonomic as momentary buttons on the grip on the control lever.
JasonW
383
191
Al
That control grip looks good. This gives me some more to think about. Also I noticed that they don’t list prices on their website.
7,997
In November of last year I paid $270 for the X Series four button in a diamond pattern and no trigger (optional). I ordered the grey finish rather than the black shown. It's a very nice grip that looks to be a quality part. The optional adapter though nice, was a waste of money at $45 or so.
MtnViewRanch
853
293
Lakeside Ca.
Not to sidetrack the thread, but McMXi, what hole size adaptor did you get? 1/2" works perfect if you finish making the adaptor. It needs to be a 2 piece, piece. The adaptor for the grip, and the adaptor to attach to the flat bar of the rear remote lever. 1/2" round stock 1 3/4" long with roughly 1/4 of the round stock machined flat for the attachment point to the flat OE lever.
My recommendation is to cut the OEM lever down to take away from the additional height that the control grip adds.
7,997
I got the 1/2" adapter that clamps over a 1/2" rod. My first thought was to remove the lever, cut it down to the right length for the control grip, and then weld on a 1/2" section of rod for the adapter. But then I realized that I could simply cut the lever down and weld on a bolt shank sized for the threads in the grip. That would be the cheap way but would require a lock nut, so not as elegant as the adapter.
Did you make the 1/2" section with the flat and threaded holes?
MtnViewRanch
853
293
Lakeside Ca.
I did, all stainless. This is what gets used most of the time for rear remotes. As in most rear remote levers that are not attached directly to the control valve are flat stock. The round holes in the adaptors work well for loader joysticks.
Sorry about the poor picture, but all that I have at this time. :(
JasonW
383
191
Al
Well to follow up I went with the summit hydraulics 4 circuit diverter. Got it installed today but still need to get some hydraulic hoses made up for it this week.
biketopia
Feb 15, 2024
299
279
Warrenton VA
Keep us posted and share some pictures!
JasonW
383
191
Al
Got the hoses made up this morning and put together. Hooked up my box blade, it works as advertised and definitely more cost effective and adding more factory remotes unless a different type is needed.
When unhooking I did have to relive pressure on the lines with the engine off, as they do not connect/disconnect under pressure.
Yes the factory toolbox is a tight fit, I had to massage it with a heat gun to make it fit in the factory location. I have a cargo basket mounted to the rops with a larger toolbox but I keep all my hitch pins and such in the small one. Can never have enough storage.
I do plan on fabricating a brace to support the manifold block from underneath. It’s not flimsy but it’s not as secure as I’d like it to be.
8,187
Couldn't you have just moved the tool box left to clear?
JasonW
383
191
Al
I could. Although I was out of hardware and it didn’t leave the solenoids as exposed from the top. I could have put the oem toolbox on the left and the multiplier on the right on top but originally I didn’t want it up that high.
7,997
I like the way you ran the hoses from the rear remotes to the diverter. Looks good, hoses look nice and relaxed. Are you controlling the outlets with the switch box that comes with the diverter, or did you go for one of those fancy Control Grip variants?
