MOOTS
MX6000
Jun 27, 2019
2,030
2,424
Canton, Georgia
BAM! Instagram welder here boys! 3 passes each side on the outside, 2 on inside. Turned heat and wire speed down for final “pretty” pass on outside.
Reactions: 14 users
7,203
Well I made a decision and went with it.
Someone welded a shelf right in the way… I will only be able to weld the inside on 3 of the 4 walls. Should be fine.
I wonder who would do such a thing!! 😂
I doubt you'll have any issues, but as you mentioned earlier, it would be easy to add gussets to the receiver tube if needed. I added three gussets to support the 3" square tube when I made a receiver for the M1078. The angled gussets provide vertical and horizontal support.
biketopia
Feb 15, 2024
202
151
Warrenton VA
I laughed too hard first thing in the morning at the shelf in the way comment. That looks good and will work just fine. Do you have enough room to get a hitch pin and cotter key in?
pokey1416
Jun 24, 2020
567
842
SW Michigan
Cleaned up driveways Friday twice as we got almost a foot of snow, added to earlier in the week. When I first started plowing in December the ground wasn’t frozen so I barely pushed off of drives and now we’ve been inundated with snow in February it will be close to running out of room in a few spots. Can’t beat a blower to solve this problem.
Oh, all of you with loaders check the 2 small screws in the front side of the stick in the handle. Both of mine were loose and 1 almost fell out. I’ve got 650 hrs on tractor.
woodman55
L6060HSTC, RTV 1100
May 15, 2022
969
780
canada
Blowers start to shine, once you start to get a lot of snow. They throw it farther, and pack in down more than a plow. I have used both, blades for lesser amounts as they are faster, and blowers for larger amounts.
7,203
I used both tractors yesterday to push and blow snow but no photos.
I received a text from the local Kubota dealer telling me that the three pieces of rear defrost glass for the M6060, along with a 100A alternator, rear windshield wiper kit and switches has arrived. Total cost is $1309 which includes a measly shipping fee of $34. The wiper kit is $297 and the electric defogger kit with the 100A alternator is $978 and those are the prices shown if you use the "build my Kubota" tool on Kubota's website for the M6060/M7060. I think the price is very reasonable for all that the kits include, so don't forget to order accessories through sales and not parts.
When the weather is nicer I'll finally get around to installing the air ride seat pedestal. The seat has to come out the rear window so it makes sense to remove the original rear window, get the seat done and then complete the rear defrost, wiper and alternator upgrades.
JonM
Kubota Grand L6060
Nov 29, 2024
wisconsin
moving snow from around the horse feeder and the horse's loafing shed. moving em in to the new barn and paddock friday. just got done with loading 20 large square bales into the hay storage.
