D722 not charging. VR output low
mrburt
Mini excavator with D722
Feb 4, 2025
17
NC Idaho
3 new voltage regulators; original, one warranty and one acquired independently.
All three VR outputs are 11.9 volts with no load; battery voltage when connected. Checked at max RPM.
Confirmed AC volts per spec from dynamo. Swapped dynamo leads.
Confirmed ground with meter and replaced ground wire.
Grounded VR case.
Confirmed 12v control input voltage when key is on.
All voltages checked at pigtail from VR on VR side of connector.
Confirmed glow plugs off when not in preheat.
Confirmed all battery connections/grounding, cleaned/bonded connections.
Performed charger repair cycle on battery.
Battery charges to 13.1 volts with Genius 10 charger.
Stored over night in an insulated but unheated garage.
Slow turn over. Barely started @ 12.33v.
Ran a tank of fuel out at full throttle voltage 12.36v. Possibly charged some but now battery is pretty warm for running for 2+ hours.
If the LED work light is on the voltage drops to 12.3v.
Only thing left is a weak battery or the fuel pump and/or SOV draw excessive current.
5,357
Ideas...
1) do load test on battery ( what's it's CCA ? )
2) swap in a new/known good battery (biggest CCA that'll fit )[make SURE posts ARE correct orientation]
3) how cold is it
4) put ammeter between battery and regulator and SEE what the charge current actually is.
5) fan belt tight ( 1/2" deflection ?? )
mrburt
Feb 4, 2025
17
NC Idaho
Ideas...
3) how cold is it
#1 is next step. It's 16 bolts to remove battery
#2 done but no diff on short run.
#3 32F
#4 not done yet but voltage is the same everywhere
#5 not loose.
5,357
OK, kinda important.. as this is a 'dynamo', it's probably good for 12-14 amps max output, so have you any 'heavy' loads ,like lights ? on the mini exc.
ugh,16 bolts !!! Nobody's stealing that battery ! Best have a box of bandaids handy.
It could be a weak battery.
mrburt
Feb 4, 2025
17
NC Idaho
#3 32F
#5 not loose.
Bought a new battery. No change. Fully charged drained down to 12.25 while running at full throttle. Polarity correct.
mrburt
Feb 4, 2025
17
NC Idaho
What is the voltage at the Dynamo?
Depends on RPM and load. Connected and at full RPM output is 20VAC as per the spec.
Swapped leads just for... no change
New battery no change.
Nothing but the fuel pump and SOV.
Glow plugs are a big drain but they cut off after start.
Replaced battery, no change.
5,357
Yeesh, sounds like you've got a fairly large 'parasitic load' draining the battery and Dyno/reg can't keep up.
Would need to see the wiring diagram for specific help but IF you have an ammeter, pull a fuse, connect ammeter and new inline fuse in it's place. Check both 'key off' and 'running', record the numbers.
Obviously with key off, NO current ( amps ) should be the result. Add up the 'running' list, that's the total current(amps) being used.
mrburt
Feb 4, 2025
17
NC Idaho
One item that may have been missed above. If I pull the wire from the VR connector that goes to the battery, the charging output, it reads 11.9V with no load. Hooked up reads battery voltage. This would/should eliminate anything drawing the voltage down from excessive load. But I am not sure what the output would be under no load conditions.
5,357
Would need to know the rectifier/regulator you're using but generally speaking they convert AC from the dynamo into pulsating DC, so reading with a meter won't give a 'nice' value.
If it's what I think it is, it maxes out at about 14 amps ( similar to a riding lawn mower )
Is the black wire from the regulator truly grounded back to the battery -ve? 'looks ok' doesn't do it, need to confirm. Simple ohmmeter test, one probe on -ve of battery, other on the rectifier's black wire. Yeah, I know, might need a trained octopus or 2 bandaids. but an important test. IF the rectifier is not grounded, it won't function properly.
if you post the part number of the rectifier ,I'll look it up online. Be nice if the wiring diagram could be posted. Long distance diagnosis is 'challenging', but easie rthan the 2 AM call I used to have to deal with !
7,299
The only way your going to get a good dynamo test is you need to disconnect the dynamo and measure the voltage off the dynamo at full rpms.
mrburt
Feb 4, 2025
17
NC Idaho
Did that connected and disconnected. Both readings were within the spec. Like I mentioned I even swapped the leads just for fun. Unfortunately I only have a partial wiring diagram. This is a (DELETE) chinese with a Kubota D722 and they won't release any info as it is "top secret". Which is funny as for about 3-4 decades I did maintenance on Corporate Jet aircraft and their info is fully released. Here is what I've got from Kubota and modified as best I can from my work. Since the VR output is low with no load it leads me to believe there is something with the dynamo. But with the dynamo fully plugged in, at max RPM I get 20VAC. Which is spec.
mrburt
Feb 4, 2025
17
NC Idaho
See original post for info.
PN is RP201-53170. Different with different manufacturers.
7,299
Well if you can't tell me what voltage you have out of the dynamo unloaded, there is not much more I can help with.
An mrburt it's a family friendly site, watch the language please.
mrburt
Feb 4, 2025
17
NC Idaho
My apologies.
I can tell you the voltage but it varies with RPM.
What would you like? Full and disconnected or connected?
7,299
My apologies.
Need to know disconnected at full rpm.
These style dynamos can cap the output voltage when they go bad.
mrburt
Feb 4, 2025
17
NC Idaho
Mananna. Too cold at present. As I recall it was 20VAC connected but don't recall unloaded. I'll top the battery and run after the garage is warmed up.
This is new BTW and supposedly under warranty so I am waiting for a reply from China but they produce a vacuum so not holding my breath. The VR took 5-6 weeks to get.
Tomorrow
7,299
One thing to note, that dynamo is very small 8.5amp working.
If you need it to run anything more than just charging a battery after cranking, I would cut my losses and put a one wire GM alternator on it!
5,357
yeesh, you can get them off amazon, next day....
checked ,the dynamo's rated for 14 amps, the the rect/reglator is 6 pins, black MUST go to good ground.
I'll have a look see if I can find an actual schematic of what's inside the 'regulator'
20 volts going in is good,
I'm supposed to get freezing rain at 3AM tonight.....probably get the 'leftovers from you , thanks !
OK, grabbed and turned your diagram and 'they' show pin 2 of the regulator going to a 'ring' terminal that is screwed into the 'frame'. If possible run a wire (16ga+-) from there to the battery -ve.
If there isn't a GOOD ground, reg will not operate properly.
