3 new voltage regulators; original, one warranty and one acquired independently.
All three VR outputs are 11.9 volts with no load; battery voltage when connected. Checked at max RPM.
Confirmed AC volts per spec from dynamo. Swapped dynamo leads.
Confirmed ground with meter and replaced ground wire.
Grounded VR case.
Confirmed 12v control input voltage when key is on.
All voltages checked at pigtail from VR on VR side of connector.
Confirmed glow plugs off when not in preheat.
Confirmed all battery connections/grounding, cleaned/bonded connections.
Performed charger repair cycle on battery.
Battery charges to 13.1 volts with Genius 10 charger.
Stored over night in an insulated but unheated garage.
Slow turn over. Barely started @ 12.33v.
Ran a tank of fuel out at full throttle voltage 12.36v. Possibly charged some but now battery is pretty warm for running for 2+ hours.
If the LED work light is on the voltage drops to 12.3v.
Only thing left is a weak battery or the fuel pump and/or SOV draw excessive current.
Grounded VR case.
