5,731
First time doing some loader work with the new to me LX3310. Even though it's rated at the same HP and lift capacity as my JD4310 it ain't much of a tractor comparatively. That extra 1000 lbs of weight on the JD must count for something. I also have generic cylinders so my JD is way stronger in loader capability.
It's still the best lawn mower I've had though. I also learned it rides better with the loader on so I will probably leave it on come mowing season.
Don’t know much about a JD4310, but seems like a model that was a few years ago? Extra 1,000 pounds means a lot.
A friend had that series years ago and loved it.
Another friend has farmed for decades with older tractors. Older like JD x30 twin cylinder tractors from 1959-1960.
He bought a new 4WD Massey Ferguson a few years ago with loader. Maybe 50-60 HP.?
As a local dealer for bale wrap, wanted the new tractor to unload tractor trailers at his place.
While I warned him his new MF would be light compared to a JD 530 or 730, he was literally shocked at how light it was.
No rookie, he quickly acclimated and ballasted, etc. But it was something he talked about for a while after getting the MF.
mcmxi
6,759
NW Montana
Don't forget to ask for the old parts to be returned. They will have value to someone else who might need them for replacements should they break a glass.
I'll be doing all the work so no worries re keeping parts. When I ordered the MX I added rear defrost and wiper and the dealer gave me the factory rear glass in a box. I still have it and hope to never need it. They gave me the original seat too since it had to come out to make way for the Grammer air ride seat. I donated that to a worthy cause though. :giggle:
3,795
neighbor day again today...moved some hay bales to feed horses, then cut and hauled off a tree that fell on another neighbors house last night.
They got lucky that the dead ash only took their fascia and gutter.
There will be some minor roof repair along the drip edge and deck. Nailed up some rubber to cover the missing fascia.
Now, back to the desk job :(
Reactions: 9 users
mcmxi
6,759
NW Montana
Do you use the pallet forks to move bales around or do you have a bale spear or similar?
5,731
With EAB, good reason to get Ash trees down before they come down.
Could have been a lot worse.
Pretty stout example.
Great work, as usual. ;)
nerwin
Nov 13, 2024
255
434
Vermont
youtube.com
Good neighbors are good to have ;)
I wonder how long it's gonna take for one of my neighbors asks me for a favor.
3,795
I just use the forks. Bales are 3x3x8. I tried rolling a bale over by hand...my old hernia repairs said "no fkng way dude" ;)
Reactions: 7 users
Siesta Sundance
Oct 23, 2022
1,661
2,192
youtube.com
I have both and used both to move hay. I also have used the double spear to move items like the pallet fork attachment, that the forks normally would do.
Now there is an attachment that has pallet forks that you can convert over to a hay spear. I thought it was cool, but not practical for my usage of the two attachments. I would hate to drop the forks and install the spears every 3 to 4 days when I need to feed or vise visa.
mcmxi
6,759
NW Montana
That's a big bale! I've only moved bales once in my life and it was fun using the MX and a bale spear that belonged to the person that bought the hay. He had no way to unload a couple of trailer loads of round bales and had expressed interest in buying the MX once the cabbed model showed up. I only helped him so that he could get a feel for the tractor, which ultimately I sold to someone else.
Yeah, discretion is the better part of valor when it comes to moving heavy objects around by hand.
Siesta Sundance
Oct 23, 2022
1,661
2,192
youtube.com
I have an old hay feeder that accepts those types of bales, problem here, no one makes bales like that in my area.
That old hay feeder is probably the most efficient feeder I have. The spacing is tight and the cows tend not to waste as much when I try and cram down the smaller 4x5 round bales in it.
3,795
Neighbor uses those plastic huts with 2 "windows" per side to cover the bales. I can slip the forks into the "windows" to lift them and place them over the bales. So, a bale spear wouldn't work for that anyway.
they look like this...without the helper.
3,795
It won't be long.
Just a word of caution. Should you decide to do that, you may want to check what type of insurance you have for that sort of thing. KTAC, "inland Marine" or commercial policies cover you....typical homeowners policies do not cover your equipment off of your property.
Just sayin' ;)
nerwin
Nov 13, 2024
255
434
Vermont
youtube.com
It won't be long.
Just sayin' ;)
Good point. I definitely would only do things I felt comfortable with. If someone needed a pile of stone or top soil moved, I can do that easily. But I definitely wouldn't do anything where I could get in trouble.
forky
L2501 HST 4X4 8N
Feb 23, 2021
279
290
Wisconsin
Don't forget the number one rule!
NEVER borrow your tractor to a neighbor.
5,731
It won't be long.
Just sayin' ;)
Great advice there. Those can cover your equipment off property.
My little BX is only covered by my homeowner's policy, and it's almost 12 years old.
I've done a bunch of work on all my neighbors' places (5). Been limited to mowing and snowblowing. Pretty low-risk stuff, and I understand the risk of going off my property. Each place requires less than 200 yards on the road.
During BIG snow storms, I've had requests to blow snow on driveways half-mile or more away. I decline.
HOWEVER: Consider the scenario where you're doing loader work to "help" a neighbor at their request.
You hit their house, vehicle, electrical pedestal, well casing, curb box, sewer clean-out, etc., etc., and cause damage. Often your "neighborly" neighbors can get adversarial and ask "how are you going to pay for that? :oops: "
As a contractor, @dirtydeed is well-versed at this kind of thing. He's done some great work in VERY tight quarters, but accidents happen. Contractor's have Commercial General Liability policies for that.
One thing some/many policies won't cover for the "Average Joe with a Tractor" is YOUR liability for damage you may cause to someone else's property. Homeowner's policies may, but I don't think it's a given.
If you anticipate doing work on neighbor's property, it's not a bad conversation to have with your carrier or agent.
My limited mowing or snowblowing has never caused me much concern. I've never had that conversation. If I were to get into anything more serious I would.
Just a suggestion. We live in a litigious society. Sometimes a Good Deed can't go unpunished.....which is sad.
Not suggesting you don't help your neighbors. Our little 'hood is 6 houses. Over 30+ years, I'm the only resident that has helped all the others.
In fact, I was trespassing on one property for 6 years to mow the lawn. Stately 4,000 square foot colonial house w/barns and 1-acre lawn was a former Egg Farm. In foreclosure for years.
House adjacent next door was owned by good folks. If I hadn't mowed it, their lawn would have been adjoined by a hay field.....I couldn't let that happen.
After the first time I knocked it down (3 feet tall), I knew I was in it for the Long Haul....6 years....
Didn't do it for the Bank that had in foreclosure and paid no attention to it.... :mad:
Did it for the older folks/neighbors next door, who also have a beautiful house they take pride in. ;)
It's what neighbors do where I come from... ;)
nerwin
Nov 13, 2024
255
434
Vermont
youtube.com
You hit their house, vehicle, electrical pedestal, curb box, sewer clean-out, etc., etc., and cause damage. Often your "neighborly" neighbors can get adversarial and ask "how are you going to pay for that?"
As a contractor, @dirtydeed is probably well-versed at this kind of thing. He's done some great work in VERY tight quarters, but accidents happen.
One thing some/many policies won't cover is YOUR liability for damage you may cause to someone else's property. Some homeowner's policies may or do.
I'd def tell them I don't have insurance and that you're at your own risk haha. Even so I'd only do something for someone I've known for a long time. My neighbor came over with his tractor to help me out a few times. Most folks around where I am understand the risks of not hiring a professional haha. I wouldn't even think about doing any jobs until I have enough experience under my belt. I have family member who lives up the road so I'd have no problem driving the tractor up the road and resurface his drive way. Super easy, low risk job and I'd do it for nothing.
5,731
Good plan.
I had revised/edited my post since you quoted it. We were typing at the same time.
Don't want to discourage you from helping a relative, friend or neighbor. Just understand things aren't like they were when I was younger.
As a farm kid (literally a kid), I've pulled stuck cement trucks (empty), neighbors' cars/trucks, and a school bus with an old Minneapolis Moline.
School bus was in my own driveway after I got off. Very icy, slid off the side. Probably 10-12 kids still on. Never took them off.
Grabbed the MM and pulled it back on the surface. Back in business in 15 minutes. I was maybe 12-14?
Today there would be 4 Ambulances, 3 State Police Cars, and the NTSB investigating...... :unsure:;)
I wasn't old enough to drive a car.....
It's what neighbors do....;)
