Quick Hitch advice please
Broxi
B2601, Land Pride Pallet Forks, Woodland Mills WC 68 Chipper
Oct 13, 2024
New Brunswick
Hi, I have just joined the forum after taking delivery of my new B2601. I am new to this world and I am trying to figure out whether to buy the Pats quick hitch system or the Land Pride or Speeco E-hitch.
Every time I try and figure out what is best I end up going round in circles! I need to move on this fairly quickly and make a buying decision.
Any advice and guidance would be appreciated.
Thanks.
4,718
Buy the LandPride. Quality at a reasonable price and it will work with your tractor. I have never purchased a LandPride item that didn't live up to the quality that I expected of it. You won't regret or question your decision to purchase a quality product. You might find a lower price on a lesser-quality item, but remember you get what you pay for.
Are you from New Brunswick Canada or New Brunswick New Jersey? It does make a difference because sometimes what is available in the States isn't available in Canada and vice versa.
WI_Hedgehog
BX2370 (impliment details in Profile-About)
Apr 24, 2024
229
220
Milwaukee, Wisconsin, U.S.A.
I have a post detailing the differences, but since you're looking for a quick answer:
LandPride QH is the most convenient if all your attachments work with it.
Pat's is preferred if you have any attachments that were made before the QH "standard" was "kind of" settled on and/or attachments that fall outside the "standard" LandPride is using. Pat's allows you to snag that "available for a steal" used implement you've been holding off on for years due to purchase price.
Broxi
Oct 13, 2024
New Brunswick
Appreciate the quick replies. I will check out hedgehogs earlier post.
I am in New Brunswick, Canada and will change it on my profile if I can.
mcmxi
5,885
NW Montana
Thanks.
I know that some here really like the Pats system, but I still have my doubts that it's better than a Land Pride or similar Quick Hitch when it comes to hooking up to QH compatible implements, particularly if you have an hydraulic top link and hydraulic lifting rod i.e. top-n-tilt. The ability to move (angle) the QH around as a unit and get connected to the implement without getting off the tractor is a real benefit.
I started out with a QH05 on a BX25D and then QH10 and QH15 on the MX and M. I think I prefer the QH10 to the QH15 since the adjustable hook on the 15 seems to be more trouble than it's worth.
4,774
also
most CAT1 quick hitches are NOT CAT1 on the implement side, they're CAT2 so you need adapters,bushings,increasers to use your CAT1 implements with them.
Trimley
BX23SLSB-R-1 plus additions
Jul 25, 2023
1,125
836
PNW-WA
The adjustable hook, couldn't that be modified to accept "pins" to make the adjustment quick and easy?
My QH is an older John Deere solid hook.
Trimley
Jul 25, 2023
1,125
836
PNW-WA
also
That's the case with my QH, all my attachments have the bushings.
🤔 I could (should) modify that.
rc51stierhoff
2,886
Thanks.
Good day.
Have you looked through any previous threads? Here is one relevant to a b2601 with other links in it:
Which attachments do you plan on buying or using? Do you know the width and orientation of the pins? Grab a diagram of the QH dimensions and compare that to your implements.
I am not sure your situation but another options might be putting your stuff on dollys…that makes it pretty easy to hook up but need flat surface. Or do you have telescoping lower arms?
From your personal info I see you have a WC68…I have one that I use with my B and Pats Easy change…it works just fine. I’d recommend you decide QH or pats before trimming PTO shaft. That is the heaviest item I have on my 3pt and I got a pats just in case I ever needed to take it off in the woods. I don’t think that would be fun to hook up off flat concrete with a QH.
Anyway, depending on what all hooking up and the width of the pins is going to decide which makes sense. YMMV.
mcmxi
5,885
NW Montana
It came with pins for the hook, but I matched the location of the hook to the QH10 and haven't changed it since. Perhaps Land Pride figured that it'd be more universal. I would have bought another QH10 but the QH15 was a fair bit cheaper at the dealer where I bought the M6060.
The other issue that I ran into and why I probably should have paid more for another QH10 is the difference in the implement interface between the two. The QH10 doesn't need bushings for any of the implements I have whereas the QH15 needs 7/8" to 1-7/16" bushings on the implement for the bottom connections.
2,618
My LP QH-15 has worked great for all my LP attachments and my 1 Homestead Box Blade.
It has an adjustable "upper part" but unfortunately I can't say for certain if it works with "all" other models.
woodman55
L6060HSTC, RTV 1100
May 15, 2022
923
711
canada
My princess auto hitch needed the adapters. But I bent some 1/4x1 flat bar into "U"s and welded them into the lower hooks. So now I can just use the standard cat 1 pins.
My hitch also came with an adapter ( kind of Y shaped) so I can connect the top link pin to the quick hitch. On equip that is not meant to connect.
I posted pictures in another thread a few months ago.
Chapel Hill Vann
B2601, bush hog, pallet forks, boom pole, scraper blade
May 1, 2022
27
25
Chapel Hill NC
I have a B2601 and wrote an earlier post about Pat's Quick Hitch. I bought a unit and love it. I use it with older implements that do not fit the quick hitch measurements as well as a newer land Pride rotary cutter.
After initial adjustments, Pat's system works great for me. Be sure and buy the accessory stabilizer bar. It makes everything work better.
I am NOT knocking Land Pride, I just don't have experience with their quick Hitch.
mcmxi
5,885
NW Montana
The industry standard for Cat 1 lower hitch spacing is 28 in., and both the QH10 and QH15 comply with that standard. The standard for Cat 1 lift arm pin diameter is 7/8" so I still don't know why Land Pride decided to use a Cat 3 (1-7/16" pin diameter) on the QH15. What implement does Land Pride or Kubota make that uses Cat 1 lower hitch spacing but with Cat 3 pins? Nothing!
I have an SB1574 snow blower, RCR1884 rotary cutter, EA box blade, EA land leveler, Fimco sprayer, Herd seeder and King Kutter trailer reciever that are QH compatible. The snow blower, rotary cutter, and EA implements have a Cat 2 option which is only usable without the QH on the tractor.
I do regret buying the QH15 rather than another QH10 since I have to mess about with all kinds of bushing combinations to get it to work well with various implements. I have to deal with Cat 1 to Cat 2, and Cat 2 to Cat 3 bushings.
mcmxi
5,885
NW Montana
After looking at Land Pride's website and reviewing the specs for the various Quick Hitches, it looks like the QH16 is what the QH15 should have been. Basically a QH10 but with an adjustable top hook. The QH15 just doesn't make any sense to me but I'm certainly open to any thoughts on what Land Pride/Kubota was thinking.
This thread has reminded me to investigate the possibility of converting the Cat 3 lower hooks on the QH15 to Cat 1. I'd just need to cut a Cat 1 to Cat 3 bushing in half and weld each half into the bottom of the hook. That would be worth doing for sure.
je1279
Dec 6, 2020
724
456
Upstate NY
also
I saw recently that Good Works Tractors is now selling their own quick hitch that does not require adding bushings to all of your attachments like most do.
mcmxi
5,885
NW Montana
So after some investigation, it wouldn't be hard to convert a QH15 to a QH16. Here's a Cat 1 to Cat 3 bushing sitting in the hook. I would need to cut the bushing in half along the axis of the bore, weld it in place, then add some material to the lock so that it limits upward movement of a Cat 1 7/8" pin. This would be much cheaper than buying a QH16.
