No sir. That's not what I'm saying at all.My bad.
So just to be clear are you telling us the bevel gear failure was caused by the use of UDT and would not have occured with a conventional gear oil?
I replaced bevel gear components on that machine (2006 BX23) because I had quite a bit of slop in the bevel gear parts and it was starting to leak some axle fluid. You could rock the wheel vertically (like checking ball joints) and feel the clunk/slop. I used that machine pretty hard (landscaping business).
My issue is with the UDT leaking after the surgery (new parts and all new seals). The leaks stopped after switching to gear oil for me.
If you take a look here and on another "tractorby..." forum, you'll find its been a pretty common problem (at least with BX machines). The consensus was that the UDT oil is simply too "thin".
I'm not telling anyone what to use, I'm only relaying my first hand experience with that issue. I'm not having a problem with my B2650. Changing the axle fluid was simply a maintenance item. The history with my BX is stuck in my head.
