Injector pump rebuild L2350 DT
DrakeRemoray
L2350DT
Jun 24, 2024
46
17
Alvarado TX
Well, I was going to list all the steps out but this YouTube video was spot on!
I was not getting the injector to fire on #3 so I pulled it apart. Thank goodness I did. It was so junked up inside, I’m suprised the other injectors even fired.
All and all not to difficult. Just keep your area clean and work through the steps on the video.
DrakeRemoray
L2350DT
Jun 24, 2024
46
17
Alvarado TX
I’m getting leaks on 2 of the 3 fittings that go into the injector pump. Im
Guessing the rubber gasket is seen its last days.
5,986
The O-ring is dust / dirt / water shield, not a fuel sealing device.
Getting fuel out of there means that the 050 sealing washer is leaking.
Either you didn't torque the delivery valve's to spec or the washers are deformed or damaged.
DrakeRemoray
L2350DT
Jun 24, 2024
46
17
Alvarado TX
hmm good catch! I have been over and over the workshop manual you sent me and I can not for the life of me find where those specs are!
L35
Jun 13, 2010
475
327
CT
Did your fuel filter fail, or?
L35
Jun 13, 2010
475
327
CT
