Wheel Spacers…need source advice
WI_Hedgehog
BX2370 (impliment details in Profile-About)
Apr 24, 2024
193
185
Milwaukee, Wisconsin, U.S.A.
Thank you for the reply. I wound up buying (4) 2" rear Jeep spacers (only) and torque sticks for slightly less than the Bro-Tek 4" spacers. I'll rattle-gun them on and off as needed in similar time as I'm currently doing wheel swaps by hand. Thanks again!
2,745
Not sure what a torque stick is.
BUT I would’ve expected that four of those jeep spacers would have cost less than 50% of what the Brotech 4 inch spacers cost.
For slightly less than the Brotech price, I would’ve gone with Brotech myself.
Of course, you now have the option of cutting back to half the 4” width if you want to in the future.
Don’t forget to use blue Loctite when you attach the spacers to your wheel hub, and the spacer to the spacer. You don’t have access to check Torque on the bolts/nuts later.
WI_Hedgehog
Apr 24, 2024
193
185
A torque stick is put on the end of an impact gun to limit the amount of force imparted to the nut, getting "close enough" to the torque specification to get the job done. I think the torque tolerance is usually within 10%, which is generally "close enough" given the other factors affecting torque accuracy.
Since I change wheels twice every 3 weeks I don't plan to use threadlocker and will continue to torque 20% lower than spec. to not stretch the bolts/studs; based on 30 years experience as a desk jockey doing computer work this seems perfectly acceptable.
In that 30 years experience doing automotive customizing on the side I didn't put fasteners on using air tools (and used a torque wrench on most everything), but as a highly repeatable time savings measure an impact wrench seems useful here as the torque sticks accuracy can be verified with a torque wrench up front and also periodically over time.
Spacers: $110 (for four)
Torque Sticks: $70
Something nice for the girlfriend: $120
Total: $300
Bro-Tek 4" Rear Wheel Spacers: $280
Shipping: $30
Total: $310
2,745
In my mind, most important reason for the blue Locktite is because in order to check the bolts holding the spacer on the axle, you need to remove the wheels. But since you swap wheels so often you can just retorque them and not worry about it.
BUT…if you are doubling up the spacers, are you going to have access to the bolts/nuts holding the first spacer to the axle? If not, you might want to use Locktite there…
4,611
Henro, do you use blue Loctite on your automobile wheels? Considering that you drive 55 MPH, you wouldn't want one of your wheels to fall off because it wasn't secured with Loctite.
WI_Hedgehog
Apr 24, 2024
193
185
I'll remove all the spacers when switching back to the turf tires, hence the air impact to save time.
The past weekend tippyness made me want to get at least 2" spacers, now I have options. They arrived today and look great. Thanks go to all the members that contributed posts throughout the years.
The spacers came with pink thread lock, guess I got the girly version. :ROFLMAO:
4,611
Send it to Henro. :ROFLMAO:
