KX080-3 flail mower piping
Rob and Kylie
KX080-3a
Sep 5, 2024
Durham UK
Have piped it like a pecker... works fine when stationary
tracking or operating arm takes most of power away
Have tried many pipe options... without success
Any advice please
3,465
1,934
Rotating attachments like mulchers usually have a 3 line setup, the third for motor drain. You also need to set up for high flow at the operator interface.
Rob and Kylie
KX080-3a
Sep 5, 2024
Durham UK
Thanks for that...the femac flail has a drain from the block back to the motor... negating the need for a third pipe apparently. I have set up high flow. ... and the mower runs fast and smooth... with momentum. ... cutting light material it copes fine...when running in mid air with no load if I track just slightly you can hear the rotor loosing speed... then build back up once I stop tracking.Its similar. ... but less power loss when I operate the boom.
