Great to know - thanks. I see there are 2 sizes of tires for the LX2610. does that contribute significantly to the ground clearance, or does the LX2610 have better clearance even with the same site tires as the B2601?
Having used both R4’s and R14’s I much prefer the R14’s and my tractor spends the majority of time in the woods. There are some people saying that the R4’s are 6 ply and the R14’s are 4 ply but that isn’t true. The R14’s on my 2502 are 6 ply so just as stout as the R4’s. And the R4’s will wreak terror on your grass. I have used my R14’s in mud, snow, and grass and they perform well in all. I have zero complaints.
The LX just has better ground clearance than the B (and actually, I think it's even better than the small frame L's) even with the shorter rubber. You should be able to find it in the machine specs. I don't have the oversized tires on mine, just the standard. My tractor just makes it under my 8' tall garage door with the ROPS up. I don't think that would happen with the larger tire option.
That ground clearance does come with a drawback...I'd suggest getting some rear wheel spacers (mine are 2.5") that make the tractor feel much better.
