4,741
O
Oh no it ain’t. I’ve kicked myself more than once about not buying the hoe, let alone a thumb. I don’t have a huge long term need, but every time I find myself trying to cut enough roots off a stump with a subsoiler and then beating my poor FEL to death with a stumps bucket, I keep thinking that even if I resold the hoe , I’d have risked my tractor a lot less often.
I do not use my hoe often, but I do have a very beefy 28" root ripper for it, as well as the hydraulic thumb.
In Utopia
L175 FEL
Apr 21, 2013
605
105
Utopia,Tx/Pasadena,TX
That is an idea I need to try. I have 4 culverts that go under the road. On the outlet side is a flat shelf before it drops off into the woods. The ditch across the flat gets clogged with clay/silt and the only tool I have used is a spade. Hard work for me. Maybe I can make your idea work. Thanks for posting it !!
gg
A lot of people use an old tire on a chain.
johnjk
Apr 13, 2017
1,388
1,127
West Mansfield, OH
Moved the chicken tractor and trailer with the B1700, mowed where they were stored in prep for the millings IMG_3220.jpeg
2,399
Qusstion: How'd they get the rope/cable through the culvert in the first place?
I've used a piece of pvc pipe with a sweeper nozzle on it to water jet/drill through, then wire the chain/cable/rope to the nozzle and pull it back through.
S-G-R
LX3310
Jun 17, 2020
1,057
2,115
PEI Canada
Mowed my brother in laws 4 acres and then cleaned the deck and greased the mower. The lack of rain has slowed growth to a crawl.
rc51stierhoff
2,682
Yesterday I snuck a mow in the evening. Then today took the ‘observation towers’ for another drive and we installed and did some trimming with the fork basket. That basket sure is handy. Couple pics of the view from above of canopy (I am loving that too) and stream 🥃
Ping
BX2370-1
Dec 25, 2018
307
211
Troy, Ohio
Setting posts for yesterday for an addition to the barn. The BX is waayyyyy better than the strong back and a weak mind method I used 22 years ago!!:)
Reactions: 10 users
rc51stierhoff
2,682
Finished yesterday evening off taking care of some dunnage from the ‘observation towers’.
This morning back at it in the woods to put the last stand up. There is lots of ‘observing’ to do coming up.
I should not have waited so long to get a work platform. Makes trimming much much easier and safer. 🥃
ctfjr
L3800HST
Dec 7, 2009
1,827
2,159
central ct
I've been (slowly) working on putting up my radio tower. Yesterday went up to attach temporary guys. Today used the tractor to pick through the sections to get the one with the guy bracket already mounted on it. That one is going up next. First spray painted over the small surface rust with 'cold galvanize'.
Tractor is still great for pulling the actual pulling up of the sections and gin pole.
ACDII
Oct 21, 2021
676
419
Illinois
Finished up 284 bales of hay, just in time for the hot weather to roll in. I still have 3 fields left to cut, but rain is in the forecast. Discovered a groundhog hole the hard way, by nearly dumping the L4060. I swear all 4 wheels came off the ground.
Time to get the AR out and do some ground hog hunting. After looking around I found there are quite a few that were hidden by the tall grass.
Old_Paint
Dec 5, 2020
1,653
1,554
AL
RON-30 tower sections? ANYTHING is better than the old heave-ho method of hoisting 70+ pound sections of tower.
If you were about 1200 miles closer, I'd offer to come over and help. Been a while since I've been on top of 200 feet of tower. Hard to beat that view.
ctfjr
L3800HST
Dec 7, 2009
1,827
2,159
central ct
lol, higher than I've ever been! Our radio club put up a 160' of Rohn 45, 40 years ago and I got to see the view from that :)
