S-G-R
LX3310
Jun 17, 2020
1,047
2,095
PEI Canada
My @5elevendesignz grill guard did it's job well again.
Tools of the job
Not sure how many times this saved the grill since I installed it. This was the second time where it was hit hard enough to push it in where I had to massage it back to shape. Well worth every dollar I spent on it. I wish side guards were available for the LX.
Reactions: 10 users
6869704x4
L45TLB, 49 8N, 57 641, RTV-X1120D, Z422
Jun 29, 2011
258
296
SE, NM
Per ASTM, 2 threads in the nut will hold the shear strength of the bolt. Not sure I would agree either, but if Kubota can save $.03/bolt……I prefer to see at least 2 threads sticking out of the nut. My experience in MV switchgear has never been pleasant with short bolts.
That does sound crazy. Was taught in A&P school that at least two or three threads need to come through the nut for proper torque. Who's right?
Paging runs with scissors!
ACDII
Oct 21, 2021
674
416
Illinois
I finally got some time to get my B2410 cleaned up and some maintenance done on it. Did the oil and filter change, as well as air and fuel and topped off the hydraulic fluid. Since my barn is full of hay it has been sitting outside and there is some nasty stuff floating around, the tractor looked like it was sitting outside for years instead of 2 months. Power washed it and looks good again. Just need to get a regulator for it and it will be back to full strength.
I had some leftover scraps of tint and applied it to one door and the windshield of my L4060 so now I no longer get blinded in late afternoon. The dealer finally replaced the EGR valve a few months ago, and has been trouble free since. I need to get the fields cut but I have no where to store the hay. My neighbor plans to buy it all, but is doing it small batches at a time, and in the mean time I lost 210 bales due to rain. Could not get it moved in time. So for now just letting the fields grown.
Swamp Tractor
Kubota L301
Aug 11, 2024
Givhans, SC
Well, new here to the site… I’m looking at my L3901 that is partially submerged under water due to the flooding in SC on the Edisto River!!! It’s fresh water but I’m debating on cranking it and moving it until the water goes down. I can’t find any information on max fording through water. Thanks for any advice and this is a great site!!!
1,168
There are two strengths for a bolt. The shear strength is when it is being loaded ”sideways“ like it is a pin. In that case you are trying to cut the bolt into two (or three) pieces. The nut is simply acting like a pin or circlip to hold it in place as it is being cut. That is what the post shows where this discussion started.
The second strength is in tension (pulling the head) and does require the full nut engagement with a couple of extra threads to get the full tensile bolt strength.
For simplicity most people are taught that ALL bolts must go through the nut. And that is best in both conditions and easier to always do the same thing.
Here is a link to more information if you are interested
1,168
You didn’t get the picture to post. I think you need five posts before you can put in a photo.
But if the water was above the air filter inlet DO NOT try to crank the engine!
if it was up to the axles and still sitting in the water I would move it out of the water under its own power or pull it out is probably best.
Swamp Tractor
Kubota L301
Aug 11, 2024
Givhans, SC
It is up to the axles but not up to the air inlet. I was a little worried because hydraulic filter and oil filer are partially submerged. River crested last night and is going down. Still might just wait.
lynnmor
B2601-1
May 3, 2021
1,397
1,105
Red Lion
Note that the picture in their article shows a typical bolt with threads that are not complete for nearly two threads.
BT3101
L3130 GST, FEL, Taylor Way BH W/Subframe, Rotary Cutter, Pallet Forks
Mar 20, 2016
Evansville, IN, USA
Picked up 225 bales this afternoon. Here in S Indiana, we've had 4 days of incredible weather for August. Low to mid 80s and low humidity. Normally we are in mid 90s and high humidity, making it miserable.
Picking up hay was fun!
Reactions: 8 users
4,420
Don't even think about starting it because you can do more damage to the tractor than the water will have done. See if you can get a neighbor to pull it out with a large tractor, or have a tow company come to the site with a roll-back truck with a good winch. Have it winched out and onto the back of the rollback. Bring it to your driveway, and pressure wash all the silt off of the tractor first. You might have to wipe it with a cloth and some Dawn dishwashing liquid to get it clean. If you have insurance on the tractor, take lots of pictures as you clean and before it is moved. Only when it is fully cleaned, carefully wipe around all the dipsticks and check the fluid levels. If they are high there is water inside the cavity. Consult with your dealer before doing anything else. If you have insurance the insurance company will tell you what to do. It might be a total loss, or they might pay to have the dealer service it. If there is no insurance, then come back to this site, and the Kubota knowledgeable people will give you instructions on how to proceed so you don't do any damage to the engine or transmission. I know that you are anxious to get started on getting the tractor running, but in your haste, you might be costing yourself thousands of dollars worth of damage. Learn from others mistakes that have done the wrong thing when their tractor has overturned or wound up in water.
Calling Whitetiger and North Idaho Wolfman to the rescue. Our local Kubota enginee experts!
2,621
1,379
We've had several days of great August weather down here in the mid-South also. Not quite good enough to inspire hay hauling, though.
The Evil Twin
L2501, LA526,
Jul 19, 2022
2,601
2,580
While i dont know your model specifically....As long as it hasn't hit the oil fill/ dipstick level in the engine, you should be good there. Same goes for the transmission and hydraulics. If it wasn't leaking oil to begin with, the submerged filters won't let water in. The front axle oil should be changed if it is 4wd. The axle was probably underwater.
Note the water line and thoroughly check for any breather tubes below that point.
