It started raining hydraulic oil from under my cab yesterday. Main hydraulic feed line from the pump failed with a hairline crack in the hardline at the bend located under the seat. Wish me luck trying to replace the line without removing the cab...
This is maybe a bit different from what you and @Old_Paint are saying, so I'll ask before getting myself in an unforeseen situation on my part:It's best to have the male and female connections. When the attachment is not in use, the male/female connections can be mated together to keep them clean and no pressure on the cylinders.
From my experience, in regards to tractor(s) FEL hydraulics, best to hook up the lines when the fluid is cold(haha I'm in S. TX.) and the attachment is not in full sun. Once that fluid is hot and expanded it can be difficult hooking up the connectors.
I have zero issues with the skidsteer on hydraulic temperatures, the hyd manifold has built in pressure relief type system. Just have to push in the hydraulic connections inward prior to hooking up the connectors/hoses.
Or you can identify the hoses with wire ties, colored tape, paint, etc, so you know which hose goes where.This is maybe a bit different from what you and @Old_Paint are saying, so I'll ask before getting myself in an unforeseen situation on my part:
As I'm adding a third-function on the FEL it would be wise to switch the Male-Male fittings that came in the kit to Male-Female?
Similarly with the Top&Tilt on the three-point hitch having 4 Female connectors switch two to Male?
I was planning on using colored plastic zip-ties on each pair (after reading comments here on not spending a lot of coin on custom solutions), but since I'm new to hydraulics (and there's a lot to understanding them) it seems best to ask first.Or you can identify the hoses with wire ties, colored tape, paint, etc, so you know which hose goes where.
You do you.This is maybe a bit different from what you and @Old_Paint are saying, so I'll ask before getting myself in an unforeseen situation on my part:
There's a small access panel for abnormally small child labourers to fit into, the rigid pipe runs under the floor to the pump at the motor. At least I can see most of the pipe run after pulling off the shields on the outside of the machine. Can't get my hands in the space available between the loader backhoe frame and cab...can look but not touch!Is there a floor pan under the seat you can remove if needed ?
Do you have access to grind and weld the crack?There's a small access panel for abnormally small child labourers to fit into, the rigid pip runs under the floor to the pump at the motor. At least I can see most of the pip run after pulling off the shields on the outside of the machine. Can't get my hands in the space available between the loader backhoe frame and cab...can look but not touch!
So much work for such a small item! Good luck with itIt started raining hydraulic oil from under my cab yesterday. Main hydraulic feed line from the pump failed with a hairline crack in the hardline at the bend located under the seat. Wish me luck trying to replace the line without removing the cab...
Nice pics of your work. Hoping for a speedy and full recovery for your wife.Haven’t done much on either Kubota lately. Been going back and forth to Mayo Clinic trying to get wife fixed. She isn’t dying but isn’t right either. A pair of 1,000 mile round trips with the Airstream and more days out of town than home the past two weeks has kept both the L and T garaged.
Most times our son/neighbor would do at least basic maintenance on the place while we were gone but he was traveling on business and was gone a couple days more than we were those two weeks. Not a big deal since nothing was growing anyway after 6 weeks of scorching temps and no rain. Except… according to the rain gauge we got near 6” of rain out of a series of thunder storms while we were gone.
So, over the past couple days: I got out the T to mow the yards along son running the older Cub ZTR. Weeded the flower beds. Hit the “volunteer” grass in the gravel areas with glyphosate. Found a yellow jacket nest while spraying around the old pet graveyard, got stung about a dozen times, came back after they calmed down a bit and killed every last one of the little yellow demons. (Apparently insects don’t know you shouldn’t start something you can’t finish.) While the “dead men walking” yellow jackets calmed down, the L hauled sticks from the road, yards, and cleared areas around the pond; dead stuff from self-pruning mature hardwoods shaken loose by the recent storms. 4 grapple loads of them.
It’s still far from being ready for a Better Homes and Gardens photo shoot, but at least now it looks like people live here. Amazing how fast things get shaggy and shabby if you just do nothing.
View attachment 134060 View attachment 134061
I could try and TIG weld in place. I think it would be better to bite the bullet and replace the primary high pressure line. It looks like it's failing on the weld seam. Like a bad zipper it's starting to unzip itself in the middle of the bend.Do you have access to grind and weld the crack?
I'd replace the pipe. Welding thin stuff sucks, and if one area of the pipe is thin another area is likely thin. Sure, it could be just that one pin-hole, but you have to pull the line to weld it anyway because heating steel to 2,220°F with a layer of hydraulic oil inside it is (from personal experience) probably not the wisest thing to attempt.I could try and TIG weld in place. I think it would be better to bite the bullet and replace the primary high pressure line. It looks like it's failing on the weld seam. Like a bad zipper it's starting to unzip itself in the middle of the bend.
I assume you went to the primary Mayo Clinic in RST, MN.Haven’t done much on either Kubota lately. Been going back and forth to Mayo Clinic trying to get wife fixed. She isn’t dying but isn’t right either. A pair of 1,000 mile round trips with the Airstream and more days out of town than home the past two weeks has kept both the L and T garaged.
Edit: Just remembered, a few days before we left, had gone around with a pole saw and cleaned up all the dead stuff I could reach so the 4 grapple loads of limbs was just the stuff above about 25’ I couldn’t reach.
Our outing was to the Jacksonville, FL facility. It was a quite unique facility and experience. Compared to other hospitals and medical facilities I’ve been involved with it seemed to be several notches above.I assume you went to the primary Mayo Clinic in RST, MN.
Was sent there for several executive physicals over the years.
This time, on my own, for a kidney tumor evaluation.
An absolutely fantastic medical facility!
