L4850 wont go into gears or move
Proline
L4850 tractor
Jul 26, 2024
9
Land01cruiser
Hi all
Have a L4850 tractor purchased as a project , i have got it running but cant get it to move, the selector in side of steering wheel is stiff and wont really budge and the gear selectir will only slide across in neutral and wont ho into a gear.
Is there a particular way to get the tractor to move, have pushed in clutch tried to move selector ect got seem to figure it out might be linkages?
First time with a kubuto had a few tractors this has me stumped
Wayne gv
Mx5200hsd
Jul 31, 2024
21
Wellington, Colorado
Hi all
Kubota made an updated plastic insert to limit the handle. Not allowing it to shift between two gears! Your photo doesn’t show it.
Proline
L4850 tractor
Jul 26, 2024
9
Land01cruiser
Thankyou for that I have degreased the top of gear shift area and will be removing the plate to see if linkages are bound up will take photos , I don’t get to work on it everyday as work away but will hopefully have this remove today
1,701
I have no idea what type of transmission that tractor has but if it has manual transmission there may be shift forks that are out of place or the transmission may be in two gears at the same time.
You may have to take the transmission top cover off to see what is wrong.
Do you 100% understand how to get the tractor’s lever’s positioned so the tractor is supposed to move? Do you have a manual to follow?
Proline
L4850 tractor
Jul 26, 2024
9
Land01cruiser
You may haven to take the transmission top cover off to see what is wrong.
Havnt as yet and no manual with it just getting advice from different people will be taking off today to see if jammed even the steering colon forward reverse selector stuff and needs to be tapped at the nuckle
Proline
L4850 tractor
Jul 26, 2024
9
Land01cruiser
Took gear linkages cover of that attached gear stick it seems to be seized will slide side to side for ea linkage but won’t turn if you move stick so assuming seized inside the barrel, so will soak for a day or to in diesel hopefully free it up
Proline
L4850 tractor
Jul 26, 2024
9
Land01cruiser
Don’t no what it’s called but is for the forward reverse lever next to steering wheel was seized wouldn’t moved, tapped it back and fourth and it freed up so put the step back on had fixed the seized gear barrel so selecting gears fine but still won’t move
