OK explain it, my old country boy brain doesnt understandintelligence is the ability to adapt to change.
The idea is that your brain can interpret the symbols and letters and read the statement without you having to focus too much. You are probably trying too hard.OK explain it, my old country boy brain doesnt understand
I didn't say the rules were intelligent, and the TSA doesn't make them. It's just that some are more diligent in enforcing them.The Kiwi TSA takes the 100ml limit very seriously and impounded my toothpaste.
never understood that as you can 'modify' a carry on ,working laptop to 'meltdown',possibly taking the plan with it.
Compare the original photo to the phrase that has been stated as what it’s supposed to say.OK explain it, my old country boy brain doesnt understand
Great answer to skeet’s question…LOLI didn't say the rules were intelligent, and the TSA doesn't make them. It's just that some are more diligent in enforcing them.![]()
OK I have got to dumber than a box of rocks, cause if you dont know the words in the first place it still means nothingCompare the original photo to the phrase that has been stated as what it’s supposed to say.
Write the words physically in the same order on a sheet of paper as the image shows.
Then looking at each word, you can see how a letter was replaced with something else in the image.
After you do that, you can read the image without worrying about replacing any letters… It makes sense to your mind.
I didn’t see it at all, but I adapted to today’s world. I plugged the text of the original image into an AI bot answer in 10 seconds or less. With my Apple iPad, I could copy the text from the image without having to retype anything.
Hope this helps…
Edit: just noticed that window was still open on this iPad. This should make it even easier:
The text you provided appears to be a form of leetspeak, where letters are replaced with numbers and symbols that resemble them. Decoding it results in the following:
1. **N73LL1G3NC3** = Intelligence
2. **15 7H3** = Is the
3. **4B1L17Y** = Ability
4. **70 AD4P7 70** = To adapt to
5. **CH4 NG 3** = Change
Putting it all together, it reads: **"Intelligence is the ability to adapt to change."**
Awwww, you should have told him it's a secret government cipher!intelligence is the ability to adapt to change.
