Considering a compact tractor for mowing. For anyone with a 60 inch deck, how is the finish cut compared to say, a zero turn. Specifically, is the blade speed sufficient to get nice cut, and do the r14 tires tear up the yard? Thanks for all replies
FWIW, R4 tires are considerably worse in snow than are turf tires.I've started using a BX for mowing in the past few months, using the 60" deck. The cut quality is better than my Husqvarna riding mower it replaced, and less likely to scalp any areas (I have lots of hills, knolls, dips, etc). I can't compare to a ZT as I don't have one, but you can't tell the difference where my yard adjoins the neighbor's yard where he mows with a ZT. I haven't gotten down on the ground to actually examine the cut on each blade of grass, but no complaints on mine. It mows the all-grass areas very nicely, but I have to slow down a bit more for the tougher crabgrass areas. I typically mow at 3k rpm, so blade speed doesn't seem to be an issue. Clean cut, no stragglers.
I'm running turf tires, with NO extra weight on my machine aside from the mowing deck. It's close to tearing grass up on the full-lock, tight turns, but so far, no worse than the old mower. The BX has much better traction due to the weight though, so I'm not spinning an inside tire like I often was on the old mower, so I'm definitely tearing up less grass that way now. With a full set of wheels and R4 tires being only $500 from the dealership, I'll be getting a set to run in the winter and put the turfs in storage.
