Thanks,, I’m just getting used to the machine. She only had a 100 hrs on her. And was kept covered for years. Runs great. 40 years on the water, so I’m a duck out of water.Yes, but depending on WHY the tire/wheel is leaking.....might be better to just fix it. With a tube, IF you have a puncture....you'll need to remove the tube to repair it.
Got tired of small leak between rim halfs on front of b2150 so in went a tube today.... corrosion between rim halfs and rubber seal leak....repainted inside of wheel and new tube....done.
pump it up - slather on soapy water & see what you see
check & tighten valve stem core?
Where did you get your tube and what size was it? I have the same problem with my front tires and I think a tube is the best first step. Finding the same size tire I need for my b2150 has been a challenge. Current tire is 24x8.50-12 and I have patched it multiple timesGot tired of small leak between rim halfs on front of b2150 so in went a tube today.... corrosion between rim halfs and rubber seal leak....repainted inside of wheel and new tube....done.
Never found exact size but with tubes close is good. (Fix / sold tires 45 years)Where did you get your tube and what size was it? I have the same problem with my front tires and I think a tube is the best first step. Finding the same size tire I need for my b2150 has been a challenge. Current tire is 24x8.50-12 and I have patched it multiple times
