While working with my B2650 the oil pressure light came on and off a few times intermittently and then shortly after the tractor just died. There's plenty of oil in it. Any thoughts
300 hours. Filter changed about 20 hours agohours on machine?
filter changed when?
I agree - don't jump to premature conclusions.How did it die? Suddenly, or slowly, like it was under load (ie oil starvation). The two incidents may be unrelated. Get mechanical oil pressure gauge that you know is good and install it. You should get oil pressure just from cranking the engine, even if it doesn't start. If you observe pressure, the stall issue may be something else like fuel starvation.
I would test the sensor, if faulty the machine will not startWhile working with my B2650 the oil pressure light came on and off a few times intermittently and then shortly after the tractor just died. There's plenty of oil in it. Any thoughts
The B2650 tractor will start and run just fine with the engine oil pressure switch unplugged. Its only function is to turn on or off the oil pressure light.I would test the sensor, if faulty the machine will not start
Yea I was a little baffled by this statement too.I would test the sensor, if faulty the machine will not start
Unplugged..... yes, it will runYea I was a little baffled by this statement too.
Also, plugging into a faulty switch will not affect whether it will run.Unplugged..... yes, it will run
