2017 Chevy Silverado A/C
4,308
I have the Ecoboost in my 2019 Ford Platinum, which is a good engine. I don't know how well it is in the truck. I see a lot of 1,2, & and 3-year-old used trucks on the dealer's lot, and while it isn't a huge savings buying used, it is an option. I bought my '19 used in 22 with 19K on it and an extended warranty from Two Rivers Ford in Tennessee for an additional $2200 which covers the car for 8 years and 100,000 miles. The warranty would have been a couple hundred less if I chose the $100 deductible, but from experience, you pay it upfront with no deductible or each time it goes in for anything under warranty. The only repairs that I have had were with the entertainment system. A module failed and the antenna failed.
4,394
I’ve had 6 of these Silverados since 1997. All red, new, and kept them 5-6 years. Northeast winters are tough on vehicles.
Had great luck with them.
This one is 7 years this month.
Wife’s car is also about 7 years old.
As we all know, the market has been funky for the last few years. Haven’t been eager to dive in.
4,394
Did some more internet research.
2014-2019 noted for condenser failure. Thought series was 2014-2017, but maybe condenser overlapped into next series and 2019? Couple tack welds hold condenser to tank - - big bumps can cause welds to crack/leak.
Blend door actuator also common problem for a couple series.
Looks like a real treat to get to. Not sure I can fit under the dash to get to it. :oops:
Not too proud to say it's beyond my expertise and ability......wish one of you smart guys lived close by...
Appreciate all the help and guidance.
Heck, I haven't figured out how to save a radio station. ;)
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
1,913
1,008
Near Lancaster, PA, USA
We were planning on a new vehicle when the pandemic / chips created the price surge. Now prices seem to be softening somewhat and we might start re-looking for an SUV.
Ktrim
Dec 23, 2020
320
177
Nazareth Pa
Failed condenser would be a leak. Compressor wouldn't be running, cutoff switch, and you say line is cold.
Blend door actuator. Find it, put your hand on it and adjust temp. See I'd you can feel it running.
4,394
My thought as well.
Like I said, I’m not sure if I can physically get into the middle of the dash to get to it.
Wish I had put the IR thermometer on the line…. Wasn’t 40 degrees, but maybe 50+ or so?!? Was covered with condensation.
Ktrim
Dec 23, 2020
320
177
Nazareth Pa
My thought as well.
If it's cold and condensating you should have cold air. On that you may have to remove center dash. Climate control ,radio. Not sure. Don't have one to look at.
Ktrim
Dec 23, 2020
320
177
Nazareth Pa
Is it manual air or auto dual control. Driver and pass separate.
Torinodan
T1600, G4200, G5200, Ford 2810, 1974 Wheel Horse C100
Oct 14, 2021
188
85
Fayetteville GA
Glove box and upper storage. They packed it in there behind a bunch of other modules.
This brings up a good point if dual climate control. Is it not cooling on just one side? Both would be the main blend door.
Because of the variable displacement pump the suction will not always be frosty. It's on demand depending on what the control thinks you need. Max cold, full fan, and vent settings only to get it to its coldest temp.
Harbor Freight has a cheap set of gauges and black lights.
Also, the high side port is the one time use rubber plug port that will leak. Slowly open till you just read pressure. Normal Schrader valves are available to replace it.
4,394
I have not put gauges on it as I don’t have them.
It is the dual control, and honestly I didn’t think of checking the passenger side. Might have reached over to right side once while driving and seems like it was same as left side.
Great suggestion.
Ktrim
Dec 23, 2020
320
177
Nazareth Pa
Auto zone or advance loaner tool.
BBFarmer
L3560HSTC-LE, L3301
Jul 12, 2024
Southeastern MS
Great suggestion.
If she is in fact low on freon, Look through your grille on the driverside. Just where the dryer attaches to the condenser you will most likely see an oily, discolored spot. I bet we get damn near one a week on the 14+ 1500s with a leaking condenser. All in the exact same spot. Extremely common.
