Grease is basically "wax" that holds oil until heated, at which point it releases the oil to lubricate the surrounding parts.
If you have a quality grease gun, the grease in the tip of the gun is where the "leak" originates from: as the garage temperature rises some of the "wax" melts and releases the oil, which is exactly what you want the grease to do. The smaller the tip (like a push-on) the less grease there is stored in the tip and the less oil that leaks out. Lock-N-Lube tips comparatively hold "a lot" of grease and therefore "leak" "a lot."
The trick to it is tear a half-sheet of paper towel off the roll and fold it twice, then fold it over the tip of the grease gun, and slide that into an industrial self-sealing bag (like you'd get bolts in). The paper towel is cheap and easily disposable, the bag is sturdy, oil resistant, and won't easily slide off on its own. I store the gun, an extra tube of grease, and the Lock-N-Lube rebuild kit in a narrow yet long enough cardboard box with an extra layer of cardboard on the bottom so if the gun would somehow leak (I keep it clean so it doesn't) the removable layer of cardboard is easily replaceable.
Personally I like quality two-hand manual grease guns because they're affordable ($100), reliable (no battery needed), and easy to use even if a person has arthritis or damages a hand (hold the body against a leg and pump with the other hand). The
Lock-N-Lube is fantastic for quickly greasing up and well worth the investment.
Oily rags left in a closed container can become a safety nightmare." -OSHA
Don't seal up the container "tight," let it breath. If the combustible vapor to air ratio is "too low" or "too high" it won't combust (kind of like in an engine, there's a range it needs to be in so it runs).
