Have a BX2200 that will not stay running. Only runs if you hold the key all the way to the right and once you let go it shuts off.
First thing that was tried was to replace the fuel shut off solenoid since the original one blew the back open. Replaced and tried it still continued. After some more research came to the conclusion that the ignition switch was the issue. Replaced and wired up the issue continues. Took the starter out and had it tested and that was still operating correctly but the innards were being worn down so they were replaced. Issue still continues. I am a bit lost now. Any suggestions or avenues that I should consider investigating more would be great.
