Continental engine
Ktrim
Dec 23, 2020
322
178
Nazareth Pa
Had this sitting around for a few years, finally decided to start picking away at it.
Continental y69 flat head 4 cyl. Wrapped in farmall metal. Was used to power pull behind international harvester balers and combines.
Got the plugs out and started soaking pistons. Locked up tight. If I can get it freed up and find everything I need to restore it I'll proceed.
Guess I have to get my pressurized gasoline and wire wheels ready. 🤣🤣🤣
4,872
What are you soaking them with? ATF and acetone mixed 50/50 will be the best to break things loose. Add some every day for several days and keep the spark plug holes covered.
4,604
That "mix" is OK, (like Kroil) but the acetone does not mix readily, and evaporates rapidly.
mcfarmall
Kubota M5660SUHD, Farmall C
Sep 11, 2013
1,397
1,673
Kalamazoo, MI
I wonder why Continental outsourced the enclosure to IHC? IH made their own power units of all sizes back in the day.
Ktrim
Dec 23, 2020
322
178
Nazareth Pa
They couldn't produce enough.
Ktrim
Dec 23, 2020
322
178
Nazareth Pa
That was my plan but didn't have any tranny fluid laying around. Didn't feel like running out again, wife had me running most of the day. Had a bottle of marvel put that in for now and finger tightened plugs back in.
GareyBarnett
a6
Jul 25, 2024
Australia
The term "Continental engine" refers to engines produced by Continental Motors, a company known for manufacturi
The term "Continental engine" refers to engines produced by Continental Motors, a company known for manufacturing a wide range of engines for various applications, including aviation, automotive, and industrial uses. Here are some key aspects of Continental engines:
Piston Engines: Continental Motors is renowned for its piston engines used in general aviation. These engines power many small aircraft and are known for their reliability and performance. Models like the O-200, O-300, and the IO-550 are popular examples.
Diesel Engines: The company also produces Jet-A (diesel) engines like the CD
