I have a B2620 and was mowing some taller grass with a belly mower, elevated up high to keep it from stalling out. All of a sudden it stopped moving and I also lost hydraulic for the bucket, power steering too. "Suddenly" was before I noticed a wet trail behind the tractor so I am guessing some plug came off without me noticing (I am hoping it is just that and not a crack anywhere). Still has oil. I found what the manual says is the transmission fluid level stick (0184) but I could not pull it out and did not want to risk breaking it. More than happy to use more force to see if that is showing empty.
The top of the belly mower and the pto shaft to the mower are wet and the 3 plugs from the manual look in place. It does seem to be more on the right side, looking at the slick tracks in the grass. Any thought on where to check first/if there are more plugs to check?
I was also wondering if it was ok to tow the tractor using a chain in neutral. My only tractor so I was thinking of dragging it forward slowly using a chain wrapped on a ball hitch while it was in neutral to get it out of the tall grass but is that advisable when it is in neutral (going about 400 feet)? It has one of those 'drive over' belly mowers so may need to back it up the same to take off the belly mower to get clearance to look under the tractor.
Thanks for any advice!
