Hey everyone, I'm looking for some advice how to address a leaking connection on my mx5200 w/ LA1065 front bucket
I had the tractor out doing work and on my way back once I got on my gravel drive, I noticed I was leaving behind a trail of hydraulic fluid. I traced the problem back to line that connects into the right side of the main block. My guess, I'm a parts newbie, is that it's related to the front loader system. Anyways the line connection has popped out of its fitting into the block, so oil is just leaking right out of it. I've put some pictures here in the post of the culprit connection, so I'm hoping someone has advice or instructions how to properly fit this back together. I looks like it's got a rubber gasket so it's a friction/pressure fit, but it's a very tight area to work in, so I appreciate any advice here before I go disassembling things![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Thank you in advance!
