That may be your only/next move.Okay, I’m not touching the EZ out for now. I tried pulling on the plug with vice grips while turning it and no luck. When turning it cycles between easy and hard. I assume it’s hard when the threads are crossing.
What’s my next move?
How difficult is it to remove the oil pan? It looks like I would need to remove a couple of bolts to drop the front axel and then remove the 10 bolts on either side of the pan.
That's what I'd do. Or pry with a screw driver under the vise grip jaws while slowly working it around. OP, you're going to have the same problem if you remove the pan.Maybe you can take something thin, like a putty knife, and put it under the head of the bolt and pry as you turn. It might work it's way as you put pressure on it.
Yup,.... but the pan, on a workbench, and sitting upside down, seems like a lot better working environmentThat's what I'd do. Or pry with a screw driver under the vise grip jaws while slowly working it around. OP, you're going to have the same problem if you remove the pan.
Yea you might as well just jump right in and pull the oil pan and either fix it or replace it.Okay, I’m not touching the EZ out for now. I tried pulling on the plug with vice grips while turning it and no luck. When turning it cycles between easy and hard. I assume it’s hard when the threads are crossing.
How difficult is it to remove the oil pan? It looks like I would need to remove the pin to drop the front axel and then remove the 10 bolts on either side of the pan.
I'm kind of surprised it didn't come out. If it spins counter clockwise by hand, and you *really* pull on it, it should come out.Okay, I’m not touching the EZ out for now. I tried pulling on the plug with vice grips while turning it and no luck. When turning it cycles between easy and hard. I assume it’s hard when the threads are crossing.
Good point. If that turns out to be the case, then all that needs to be done is to reweld the nut to the inside of the pan.the 'snapping sound' might have been the two tiny tack welds that hold the nut in place inside the oil pan ??
IF so,pan HAS to come off
The picture of the used pan seems to show a bung installed and welded from the outside. I would think you could see the bung spinning if the welds are broken???Yea you might as well just jump right in and pull the oil pan and either fix it or replace it.
But you will find out really quickly you can not remove the pin, you will need to drop the whole front frame and radiator to get the axle out of the way to get the pan off.
KUBOTA B5200D D750 ENGINE OIL PAN 15371-01614 | eBay
FOR SALE IS A USED OIL PAN FROM AKUBOTA B5200D --- D750 ENGINE.www.ebay.com
Looking at the pic Wolfman posted…. I’d drill it out….and ream/tap the “boss” oversized…and install a new oversized drain plug…. before I’d do all that extra work of trying to remove or replace the pan.
There are a number of aftermarket drain plugs which can do this job.
I don't think that any "smearing" of a sealant is going to solve his dilemma. This needs to be dealt with properly and repaired. I agree with sucking the oil out, and I have 2 of those draining suckers. I can't remember when the last time was that I removed a drain plug. Oh yeah, it was last summer when I changed the oil on my 1962 Chevrolet.
