Is a 900# grapple too much for a M7060 & LA1154
Merlota
Mar 27, 2024
ga
I would strongly suggest get the 72in...... get something that is wide enough where you can see the outer edge grapple sir, you have a big tractor.
I know what you mean with it being hard to see. I have enough trouble with the bucket. The extra 6" on each side makes that much difference?
Siesta Sundance
Oct 23, 2022
1,143
1,241
youtube.com
Yes sir, especially when it comes to grapple work. Knowing how deep those teeth are in the ground and/or just picking debris or material in general.
With a smaller grapple it has less protection on the tractor as well.
Trust me on this, I have 400 to 500+ hours of grapple work just on that MX.
Moose7060
M7060, Farm King PT740, HLA 2500 Snowpusher, LandPride RCR1872, Defender HD9 XT
Oct 14, 2023
155
347
bc
[/QUOTE]
Wow are you ever fast on that MX5200!
mcmxi
4,982
NW Montana
It really depends on how the OP is going to use the grapple and what type of grapple. If your grubbing brush, ripping up small stumps and small trees out, a lighter weight grapple will bend and not hold up.
If I had used a lighter, less quality made grapple, it probably would be scrap metal.
How do you equate lighter to lower quality? That's simplistic to put it mildly. I don't pick up and move sticks with my grapple. I move 2,000 lb rocks around and dig those rocks out of the ground with my 400 lb grapple. I pick up a 2,500 lb disc harrow with my grapple and a 1,500 lb plow. Hardox 450 virtually throughout, strong where it needs to be, no wasted steel and no damage after many hours of hard use, not pushing twigs around that my dog could drag out.
It's the OPs money, but steel is bought and sold by weight, and paying for 900 lb of steel when 600 lb will do a better or equivalent job makes lot more sense, regardless of whether you have 500 hours of moving sticks around or not.
Moose7060
Oct 14, 2023
155
347
bc
Maybe I am missing something here (being slow at the switch sometimes :LOL: ), but after 25 posts talking about grapple weight nobody has brought up the fact that the weight of the bucket comes off first.
Siesta Sundance
Oct 23, 2022
1,143
1,241
youtube.com
Picking up items and using force to dig and remove are different variables.
Again, I said "If I had used a lighter, less quality made grapple, it probably would be scrap metal. I also previously mentioned AR400 steel in the teeth plate.
Let me borrow your 400lb grapple and I show what the difference in my use vs your use.
