So..... was doing my my yearly matinance and checking my front end fluids the differential and what I guess would be called final drives is all connected so I usually check the sides and don't check the middle "check" plug. I was so confused at first because I couldn't find a drain plug for the front end but it drains when the sides drain and if not then someone forgot to put in a drain plug. Anyways...... to the point.
I took out the plug labeled "check" in the manual just to make sure oil was getting everywhere it's supposed to..... it wasn't a plug.... it was a bolt with a nut on it and a copper crush washer on this side. The hole is threaded but not for that bolt. So now theres a nut and maybe washer on the inside.... weird that the nut didn't just spin. It felt a bit strange when I was taking it out but it's what I'm supposed to take out to check it so I did.... sooo this is a new one
