JohnMackenzie
B6200, L3901, LA525, BH77, MK Martin 60" Mower, Agrotrend C60, ect.
So as the title says, my hydraulics on my L3901 aren't working at all, it's a DT so it's 4wd and manual, NOT hydrostatic. The tractor is only 3 years old with 430 Hrs on it so I'm not really sure why this problem came up. I have an LA525 FEL, BH77 backhoe, and two rear remotes, as far as I'm aware nothing has changed with anything, but it did sit not moving for a few months over the winter. So what's going on is the loader and backhoe will not move at all when I try any of the controls and my power steering isn't working either, All the quick connects are fully seated and connected properly so that isn't the issue. I called my local dealer and spoke to a mechanic over the phone before I decided to start tearing into it, and he said that it sounds like the hydraulic pump failed, I'm anal about all my servicing and maintenance so I've changed my hydraulic oil twice since I got it, and it is at the correct level for what that's worth. I suggested the PRV might be stuck open which he also said could be possible. I just came in from the shop after checking the PRV and taking a good look at the pump without actually taking it off the tractor (just looking in through disconnected lines) and nothing seems out of the ordinary. I just wanted someone else's opinion if this has happened to anyone of you before, and what was needed to fix it before I took the pump off to do a tear down and inspection. The mechanic said he thinks it might be covered under warranty but doesn't really know, on top of that I don't really want to have to take it in if I can fix it myself even though I'm well aware that would be the easiest, and I'm not paying $160/hr for a tech to come here just to diagnose the problem. Really just wondering if anyone else has anything to add to my list of troubleshooting tasks before I do anything unecessary. Thanks in advance ~ John
