MDinCNY
B2320 (MY2010), 60" MMM, LA304 loader, BX5455HD blower & various other stuff
Hi all,
New to the forum, with a problem that has bothered me for a while.
The loader valve on my B2320 becomes increasingly difficult to operate the higher the engine rpm. This problem only occurs in the lift/lower function, dump/curl works just fine at all rpms. Specifically, up to around 2000 rpm I have 'normal' control of the valve....meaning I can raise/lower the bucket or snowblower in small increments as you'd expect from hydraulic controls.
At full throttle, the force I need to exert on the joystick to get it to raise/lower is much higher than normal. So much so that when the spool finally moves, the bucket/blower will raise or lower a few inches. Fine adjustments are simply impossible. It feels very much like there is hydraulic pressure in the loader valve working against movement of the joystick at the higher rpms. Float detent works fine, and I've already inspected & lubricated the springs & balls.
What is causing this to happen, and what do I need to do to fix it?
