M7060 / LA1154 Loader
dhcole99
M7060
Oct 21, 2021
Ontario, Canada
Loader boom/bucket lever is very stiff when raising boom and bucket. Started about 10 hours ago (1100 hrs on tractor) and has been getting progressively worse with movement being slow/hard to engage and will not release without manually moving the lever/joystick. When the boom and/or bucket do move the speed is usually ok. I find that if I go hard 3/9 or 12/6 (o-clock) response is better but inbetween it is a hard push/pull. Rear hydraulics to blade is fine. Any suggestions as to what is causing the issue?
JasonW
244
107
Al
Could be the loader control cables. Disconnect them on one side and see if the lever moves freely.
5,172
964
Ontario Canada has been having very cold conditions in some places.
Problems with cables freezing due to moisture inside has been a recurring issue with my M7040 rear remotes.
I removed one piece of interior trim to allow cab heat to get to the remote cables.
Tell us about where your tractor is stored and the local weather conditions.
Any way to get tractor into somewhere warm to see if things change?
I think there is a metal guard protecting the loader valve which is easily removed.
Disconnect the cable connection to the valve spool as JasonW suggests and see if the cable moves freely.
dhcole99
M7060
Oct 21, 2021
Ontario, Canada
I keep the tractor in an equipment shed that is open on 2 sides but I am not sure that the cold/ice is the cause. I have noticed that it has been progressively getting harder to move for the last month (above freezing temperatures) but really came to a head after moving a big dump of wet snow. I will take a closer look this weekend and let you know what I find.
dhcole99
M7060
Oct 21, 2021
Ontario, Canada
Figured out what the problem was. I removed the lever/controller cover in the cab. I was able to see some corrosion on the tops of the pivots and there was some squeaking. Applied lots of WD40 then lithium grease to the controller and cleaned the pivots. Added WD40 to cables and links. It now works like new. I suspect that moisture and dust had worked its way up the cable and in the linkage. Something to add as part of my regular maintenance.
mcmxi
5,266
NW Montana
Thanks for following up on this.
