Hello all, thank you for all the great post’s on this forum. I am a Marine Mechanic by trade and come from that side of the mechanical spectrum. A lot of tractor related stuff is a little foreign to me with hydrostat. Etc. I am learning a lot. I thank all the previous posts i have read and have helped me with little issues i have chased.
First off my tractor is a 2015 L6060 HSTC.
I am running across one last issue with my tractor (owned it for about 2 months) and it keeps haunting me. The issues i have is sometimes the tractor will get “stuck” in gear. Sometimes in Reverse and sometimes in forward. If stuck in reverse i have to move the HST pedal to about half throttle in Forward position to obtain “neutral”. Vice versa for Reverse. This issue took a month to show up. Happened twice in a week and now has not happened since for about 2 weeks. (Resolved with letting tractor sit for a few minutes to an hour or more) The other problem is it is very jerky at low throttle input. Mainly reverse but sometimes forward. I am hoping this has something to do with the other issue.
I have read many posts and one in particular from a member peaceofprairie seems to be similar to my issue.
www.orangetractortalks.com
To resolve the issue i am having i have tried to understand the HST electronic system and done lot’s of reading in the WSM. I think i have understood the system and believe the HST pedal sensor speaks to the ECU(computer) and the ECU tells the forward and reverse solenoids/proportional valves what to do. However i have one question, what does the Swash plate sensor play a role in? Could this be causing my issue? My manual states in the section “error message does not indicate on LCD” and sub section “Machine will not stop in Neutral position” page 3-S11, it states that potentiometer damaged.
I replaced the HST pedal sensor a few weeks back and thought this had solved the issue. I did do the “fine adjustment procedure” as well when sensor replaced. The tractor has acted up since.
My question is when i go to page 9-S55 in the manual that the troubleshooting guide takes me to it lists the HST pedal Sensor and Swashplate sensor as potential culprits. It also lists the Hand throttle sensor which i assume would have no effect on this issue.
I wanted to dig a little deeper after reading the link i posted and wanted to do some more electronic testing to see what the swash plate sensor controls? .I have read up on using the Intellipanel and what a handy feature. I had it in mode A and was watching MA readings on FWD solenoid and Reverse. To start my diagnosis on the jumpy issue i placed the range selector in Neutral, i slowly and gradually applied my foot in the forward position from N to wide open, readings were very smooth and steady.
Now the good part. I try this now in Reverse and slowly apply throttle, i stop at about 1/4 throttle and notice my reverse solenoid and FWD solenoid are bouncing on and off constantly (this makes sense why my reverse is so jerky on and off.) so this diagnosis leads me back to what role the swash sensor plays and how it could effect this. I now know the forward and reverse solenoids are activating when pedal is applied in Reverse. What could cause this?? Could this also be causing the stuck in gear issue as well?
Going to make a small quick video and post a link. I feel my well written paragraphs in my head will not communicate to others well and be confusing, if you are still reading thank you for taking the time to read this.
will post up the link shortly to my video. I hope i can compile a nice thread to help others. I have ran across many threads with dead ends and hope i can take this to the finish line and help others in the future.
Josh
L3540 HST driving strange - Swash Plate Sensor fix
Hi Orange gang, Long time lurker - I've saved so much money with fixes and advice from this forum. I just fixed my hydrostat error, and thought I'd share. Symptom: Hydrostat pedal in Neutral, but tractor is moving as if it's about 1/3 depressed in the forward direction. I had to hold the...
![www.orangetractortalks.com](https://www.orangetractortalks.com/forums/styles/ott/ott/favicon.png)
Josh
