I have purchased a rear remote valve and top and tilt cylinders.
The valve came assembled and ready to mount on the ROPS. The female coupling halves were installed on the valve and they are double acting sleeves. Those are promoted as single hand operation.
I would understand that if you have the female half in your hand to push onto or pull off the stationary male half.
I also understand the way to clamp the double acting sleeve and make it a break away coupler. And in that case you can easily attach a hose with one hand since the female coupler will slide back in the sleeve.
The short question is…
Which half of a double acting sleeve coupler is supposed to be installed on the stationary rear remote valve?
