Trapper Bob
Jan 17, 2022
444
802
Andover, KS
62 Ton or ~44 yards is no joke, that's a solid day of tractor work.
Never seen the cut tire for underlayment trick.........makes sense when I think about it. How were they cut, sawzall?
There is a machine, but I have not seen it. The cuts are clean & a little rubber particles make me believe a rotary blade was involved. I have tried to cut tires in the past & the rubber would pinch the blade. It wasn’t fun. These tires were cut in advance of disposal (landfill I think). They are available, but you are asked to sign a waiver stating you’re not going to do something environmentally irresponsible with them. This is a way to get a little more use out of an oil d tire.
Trapper Bob
Jan 17, 2022
444
802
Andover, KS
The elk were checking out my work yesterday morning! I'm planning on hooking up the smaller dump trailer to the MX this afternoon and continuing to "excavate" in preparation for gravel. I'll be using the EA box blade behind the M and the loader in front to loosen and then load up the trailer.
The scenery around your “work” is wayyyy better than mine.
Siesta Sundance
Oct 23, 2022
1,512
1,861
youtube.com
You are right. Except the traffic will be cattle. Our local NRCS says the life of a stock pond where cattle can freely walk around is 17 yrs. Then, the pond is shallow because of the cow’s hooves beating down the banks & pushing mud to the center. There is a lot of weight on the small surface area of a cow’s hoof.
A pond where cattle have restricted access can last 35+ yrs. This watering lane is that spot where the cattle will be able to get a drink (& the only spot). The rest of the pond will be fenced. There will be temporary panels between the posts that can be moved as the water level goes up or down. This will limit the amount of steel exposed to water (rust).
There is more work to be done. Stay tuned😁.
Very Nice. Doing it right from the get go.
radas
Mar 21, 2022
719
833
Had no idea cattle were so complicated (and destructive), thank you for the education!
3,651
Broken water service repair today. Kind of a crappy job at a very nice home. Didn't bother taking any pictures...
36" grading bucket worked very well for the clean up. I have to remember to not be so lazy and actually unchain it from the trailer and actually use it! It's so much faster and does a much better job being "toothless".
On to another water service in the morning. This one ought to be a real hoot. Steep front yard with pole (and several guy wires) right where we need to make the connection at the curb stop. :(
5,437
Cattle as individuals are not destructive (if they have food and water) it's a herd of them that makes a difference. Kind of like humans!
Bearcatrp
Mar 28, 2023
594
320
Minnesota
Picked up my new front tire today. Got it mounted after work. 80 bucks for tire and rim. Also attached the rear blade I picked up this past weekend.
Siesta Sundance
Oct 23, 2022
1,512
1,861
youtube.com
Oh this could have been bad. Caught some horse wire(previous owner had in 1970s, generously left me pieces scattered everywhere) underneath the tractor frame, didn't make it to the shredder. This wire is thick and strong too. Glad I saw this quickly and easy fix to remove.
Goodnights!
I think this old Bute L305DT needs a LED lighr bar up front!
Reactions: 6 users
S-G-R
LX3310
Jun 17, 2020
1,090
2,222
PEI Canada
Goodnights!
Nice catch. That would of been a real chore to get untangled.
6,166
Loaded up for this week's festivities and came up with an easy way to get the plate compactor on the trailer as well. Who knew mini's could be so much fun? 🙂
Yea I use the Bob Cat to load mine, muscled it the first few times till the brain kicked in!
6,166
Siesta Sundance
Oct 23, 2022
1,512
1,861
youtube.com
ZEP orange cleaner will wipe the grease right off of it, and bonus will leave it smelling like an orange!
Can't reach all the pivot areas behind the frame/lift arms. I think I'm gonna have to start pressure washing it more often, like every 50hrs to see if that helps cut down on the amount of grease build-up.
lynnmor
B2601-1
May 3, 2021
1,440
1,154
Red Lion
Since the pins and bushings have no seals, pressure washing will force dirt and water inside. Just grab a couple rolls of paper towels and wipe out the excess grease, it's cheaper than firing up a pressure washer and blasting grease all over the place.
5,065
Are you using a HOT pressure washer?
Siesta Sundance
Oct 23, 2022
1,512
1,861
youtube.com
Skidsteer, rear pivot pins not easily accessible. All the grease in the rear falls down into the frame/machine.
Every 10hours the zerks get greased and depending on what attachment is on. It can easily use a half tube of grease every 10 hours.
5,065
No, but I think I'm gonna use the drain off the water heater next time, probably put one those in line screen gaskets that are on sprinklers so the pressure washer doesn't suck any debris from the water heater.
If you have a business (farm?) I would strongly suggest that you try to budget for a HOT pressure washer.
I have a 50 year old Hotsy (brand), electric motor washer, with only 1,000 psi.
The 1,000 psi hot pressure water will 100% out clean my 4,000 psi 13Hp Honda powered, (cat pump), cold water washer.
The domestic water heater hose method will be a bit better than straight cold water, but 200 degree water, with high pressure, and dedicated burner heated water is vastly superior.
