Show us your Shop and Equipment
Tarmy
L2800, BH76A, FEL,box scraper
Nov 17, 2009
528
494
Lake Almanor, Ca
Are some of the 427 hammers metric?
Not that I am aware of…
Besides…when I am reaching for a hammer, usually the bigger the better and something has likely gone wrong already…so I don’t care what persuasion it is.:rolleyes:
BXHoosier
BX24
Jan 21, 2018
490
566
Indiana
The cordless drill mag base works great. I used it to drill and tap around 40 3/8”-16 holes through 3/4” steel.
Today, I made a mag base tapping guide. It uses a 3/8” ratchet, a 6” extension and tap sockets. I have a Gearwrench ratcheting T handle tap wrench and a 3/8” square adapter that I can use in place of a 3/8” ratchet. Again, I had to get creative with setups on my lathe to machine it.
2,960
View attachment 97335 View attachment 97336
Might have to steal that design, looks pretty handy!
BXHoosier
BX24
Jan 21, 2018
490
566
Indiana
I needed to make a couple bends in a piece of 16ga stainless today, so I made a simple vise brake with some scraps. The welds aren’t pretty because the gas bottle ran out mid way.
BXHoosier
BX24
Jan 21, 2018
490
566
Indiana
I’ve been thinking about buying or making a milling attachment for my lathe just to have. I picked up a nice 2-1/2” vise and yesterday I sketched the pieces I need to make. Today, I made the adjustment knob and cut 0.001” graduations on it using a lathe bit, magnetic indicator base, 6” scale, and masking tape with graduations on it.
6,457
My son, our youngest, works for a manufacturer of electrical connectors for aerospace, military and other applications.
Had plant tours for employees' families and retirees. My son is an EH&S guy, so he is all around the HUGE place, and is familiar with what a lot of the departments do.
Nothing was running, but the CNC, extrusion and injection molding equipment was really impressive and modern.
One small area had machines that looked 50-75 years old. He said they would work on prototype and small order stuff.
The connectors they make are so intricate and use a variety of metals and composites. They also do a bunch of different plating options. I'm sure everything must meet tight tolerances.
As evidenced by this thread, a lot of you guys are very skilled with this type of equipment.
You all probably would have understood more of it than I did.
Given a lot of issues you guys can relate to, there's no pictures to document the adventure......
It was really impressive. Glad I went and think sonny boy liked taking the "Ol' Man" on a tour.
Dad liked it too... ;)
BXHoosier
BX24
Jan 21, 2018
490
566
Indiana
Ground the vise, milled the ends, and cut the dovetail. Made a plate for the lead screw and mounted it to the vise.
2,960
My 8ft brake:
BXHoosier
BX24
Jan 21, 2018
490
566
Indiana
Almost finished. Just need to cut about 3/4” off the top of the welded bracket.
2,960
While it is not a full size vertical mill by any stretch of the imagination,
My Dad & I made a lot of cool stuff with a 10x24 Atlas with a milling attachment in the old days.
(like this)
Sawburner
L2501, Gravely 526
Dec 18, 2022
71
183
NY
Betting its the same place my wife just retired from in Sidney. It is an impressive building smaller then the one they moved from.
BXHoosier
BX24
Jan 21, 2018
490
566
Indiana
Had some scrap extrusion so I built a bracket to hold a tool chest by my lathe.
BXHoosier
BX24
Jan 21, 2018
490
566
Indiana
Added a digital readout to my drill press. It’s an impulse buy I found while cruising Amazon. I also bought a set of 3” long vise parallels for my milling attachment.
BXHoosier
BX24
Jan 21, 2018
490
566
Indiana
Made an indicator holder for my lathe. It locks onto the spindle taper the same way as the chucks. I used the milling attachment to cut a keyway into a shaft and to mill a spacer to raise the top plate on the milling attachment.
2,960
Got tired of chasing my jewelers screwdrivers around in the bottom of the screwdriver drawer:
BXHoosier
BX24
Jan 21, 2018
490
566
Indiana
Made some improvements to my Hardinge lathe. It’s what’s referred to as a second op lathe. The carriage doesn’t feed left and right like a traditional lathe. It slides on the ways and is locked in place with a handle at the back. I made new dovetail pieces and a gib to replace the lock and added a lead screw and handwheel.
