Biker1mike
Jan 11, 2022
1,177
1,278
Gallatin, NY USA
No snow, nothing on the to do list, plenty of time on my hands.
Tractor has been sitting so I fired it up just to keep everything lubed and ready if needed,
Should be ice fishing but there ain't no ice.
Tried to load video but it just looped a black screen.
S-G-R
LX3310
Jun 17, 2020
1,074
2,177
PEI Canada
Thought I was going to have snow to blow when I got home this afternoon but rain took care of that. We're probably going to be green again tomorrow. Definitely not the usual weather for eastern Canada.
GreX
BX2380
Jan 8, 2023
180
128
Maine
Sounds exactly like what is happening down here in Maine, very odd weather, even today we got more rain, freezing rain, and a bit of snow, with a bit more rain.. no white stuff on the ground, even on the grass.
Also, I love PEI, such a cool place!
On topic - I did add the BXpanded Under Armor to my BX, seems well built and easy to install. For those of you that do have this on your tractor, and use a rear mounted snowblower, or other rear mounted PTO driven things, is there a way to lock the plate in the up position? I have the cutting length set to the highest setting, allowing it to sit a few inches below the frame, but it'd be nice if there was a way to keep it in the up (top) position?
pokey1416
Jun 24, 2020
554
817
SW Michigan
Cleaned out the zerk cups and torqued roof bolts, after taking top off a couple months ago. Found 3/9 needed torqued to spec’s.
JimDeL
Aug 31, 2022
285
298
Austintown, Ohio
There's one setting beyond the "0" on the knob, marked "T". That should keep the skid plate in the uppermost position.
GreX
BX2380
Jan 8, 2023
180
128
Maine
I tried doing this, watched a video where the guy said to raise the PTO's up which would allow it to go into higher settings, but I can't seem to get it into the zero (0) setting, which I believe is the 'Top" on the mower knob.
S-G-R
LX3310
Jun 17, 2020
1,074
2,177
PEI Canada
Same here today, tomorrow and then warming up and rain again.
GreX
BX2380
Jan 8, 2023
180
128
Maine
I was able to get it up into the top position - had to pull the skid off the mower riser - once at the top position, I was able to 'force it' into accepting with the pins. Couldn't really figure out what was the sticking point, but, its on there now.
4,950
Just planted red potatoes useing my " hiller"
Wow…. I live in the wrong place.
Don’t know any different.
Was talking to an acquaintance about Maple Syrup.
Most folks start tapping trees in about a month….we count on snow and below freezing temperatures for a while in advance of the sugaring season.
Maple season is often February to April, as Mother Nature dictates.
mdhughes
L3901DT
Dec 10, 2014
1,246
700
Ste Geneveive county, MO
Cut and split some firewood today.
One of the logs had a lot of blue in it. Was wondering what piece of metal was in it, found barbed-wire.
Magicman
Oct 8, 2019
5,424
7,344
Brookhaven, MS
knotholesawmill.com
Thankfully you were bucking and splitting rather than sawmilling. That wire would have cost a blade.
The blue is your clue.
utkdoc
14
17
usa
Do you not feel a grab when you're bucking? I always thought that would be a scary event when it inevitably happens to me.
bucktail
Jun 13, 2016
1,248
187
MN
Doesn't appear to have hit it with the saw. Looks like it was exposed by splitting.
Vlach7
L47 305DT JD500C
Dec 16, 2021
331
245
Frazier Park Ca
Buried my Beast of a GSD, 110lbs, only 8 years old. Was chasing coyotes and his normal sized brother last night, healthy and no signs of trauma. Very unexpected. He is getting an honored burial not just "Dad's Ash hole", hope the same for myself someday.
  • Sad
Reactions: 10 users
4,950
Ouch, so sorry to hear. It’s so hard and sad to lose a pet.
Lost Ollie New Years Day 2022.
