What breed are the cattle?Northern Minnesota. Opened up livestock gates with bucket. Moved snow. Put on bale spear and Haybale out to the livestock. Used the RTV just drive around and have fun. It was a good day to be outside.
Look like Highland cattle to me.What breed are the cattle?
Could you just put the carcass in the bucket?Yesterday afternoon I used the M to drag an elk carcass up into the woods to feed the birds and beasts. I also moved a bunch of bark to the burn pile and got ready to cut up some downed trees that should burn well. The snow was over 2ft deep in places and no way that the MX would have made it the 1/2 mile or more I had to go. The M is a tank and had no trouble in some fairly deep snow and hilly terrain.
It was in the sled since early November. I could have moved it to the bucket, but since the sled was already in a bit of a state I didn't want to have two things to clean. In addition, the idea was to bring wood back in the sled and the bucket, but I ran out of daylight.Could you just put the carcass in the bucket?![]()
Yeah, that's a pretty decent frame for a carry-all, and certainly has a lot of flexibility. A little grinder work, and you've got a half-decent 3PH fork lift, too. Not very adjustable, but it's designed to go under a standard pallet. I've been eyeballing one of those at TSC for a long time, but it's a bit overkill for what I need for load rating, because I don't carry anything very heavy. One disadvantage is that it's on the opposite end of the tractor from the loader meaning it can't be loaded with the loader. If it were QH compatible, I might consider it just for the convenience of not having to build a frame. Making it SSQA and QH compatible would make it a LOT more useful. I mainly want something to put light tools (axe, chainsaw, pole saw, shovel, hoe, fuel/oil cans) that I can just drop near where I'm working with the tractor when I get there. Without making two trips. I could also leave it behind the BB when I park it in the shed if I'm doing the same work the next day, or just lift the BB enough to not scrape the floor, and drive off without it. Sometimes, I'm just flattening out the mess I make while digging up undergrowth and stumps, and don't need the hand tools. Doesn't need to be heavy, just adequate for hand tools, and quickly attachable or removable without leaving the seat. I've got some sketches done. Just need some more measurements to figure out how much box beam and hardware I'm gonna need.When I built my carry-all I got a frame from TSC and put 8 60 lb cinder blocks on the floor and then put a piece of plywood over them. I still have over 3 feet of usable height in the box for other use.
If you make that, please post pics. That would be ideal for a lot of what I do. Just a light weight box that hooks to the boxblade so I’d still have the blade for counterweight and finish grading with a tool carrier that could be picked up at the shop and dropped at the worksite without a bunch of effort. Depending on the job, I might be running the bucket, forks, or grapple so making a carrier for the loader end of things isn’t ideal at all. The boxblade is more typically on the 3 point.Yeah, that's a pretty decent frame for a carry-all, and certainly has a lot of flexibility. A little grinder work, and you've got a half-decent 3PH fork lift, too. Not very adjustable, but it's designed to go under a standard pallet. I've been eyeballing one of those at TSC for a long time, but it's a bit overkill for what I need for load rating, because I don't carry anything very heavy. One disadvantage is that it's on the opposite end of the tractor from the loader meaning it can't be loaded with the loader. If it were QH compatible, I might consider it just for the convenience of not having to build a frame. Making it SSQA and QH compatible would make it a LOT more useful. I mainly want something to put light tools (axe, chainsaw, pole saw, shovel, hoe, fuel/oil cans) that I can just drop near where I'm working with the tractor when I get there. Without making two trips. I could also leave it behind the BB when I park it in the shed if I'm doing the same work the next day, or just lift the BB enough to not scrape the floor, and drive off without it. Sometimes, I'm just flattening out the mess I make while digging up undergrowth and stumps, and don't need the hand tools. Doesn't need to be heavy, just adequate for hand tools, and quickly attachable or removable without leaving the seat. I've got some sketches done. Just need some more measurements to figure out how much box beam and hardware I'm gonna need.
That's definitely a mouthfulDid some firewood yesterday. Fell another blonded Ash tree, cut it in 60" logs and used the grapple to move them to the firewood area. I was a little surprised when I was able to pick 3 of the logs up at once. When I got off the tractor to get a picture, I was really surprised at the one log. Not sure what was keeping it on the grapple. Went about 1/4 of a mile in the woods with it.
It's nice to learn a lesson and still keep it upright.Cut down a couple of trees. The ground was still soft from the rain a couple days ago. Learned a new method for almost tipping the tractor over; and a couple new ways to get bogged down. Left half the trees for pulling out in the summer when the ground is dry and solid.
Is that a Jet Sled? What size is the sled?Yesterday afternoon I used the M to drag an elk carcass up into the woods to feed the birds and beasts. I also moved a bunch of bark to the burn pile and got ready to cut up some downed trees that should burn well. The snow was over 2ft deep in places and no way that the MX would have made it the 1/2 mile or more I had to go. The M is a tank and had no trouble in some fairly deep snow and hilly terrain.
As wood goes, Ash isn't real heavy or dense. Not to mention, it's SUPER easy to split. Seems sometimes all you have to do is say something mean to it. If that were green hickory or white oak, I'm not sure the LA525 would have lifted three logs that size. Those are about 250 pounds each, just guessing, if not a little lighter. Hickory would have been at least double that weight. This late in winter, most of the sap would be down in the roots on ash. You probably still had a little weight margin on that loader, depending on the weight of the grapple, but diameter got ya. That's definitely a mouthful. It is satisfying to move that much weight/material with a relatively small tractor in a single trip. I could get two of those with my little grapple, but it won't open wide enough for all 3. I don't need (nor want) to move that much firewood, so mine serves its purpose. What is that, the EA Wicked?Did some firewood yesterday. Fell another blonded Ash tree, cut it in 60" logs and used the grapple to move them to the firewood area. I was a little surprised when I was able to pick 3 of the logs up at once. When I got off the tractor to get a picture, I was really surprised at the one log. Not sure what was keeping it on the grapple. Went about 1/4 of a mile in the woods with it.
It's an Otter branded sled sold by the local Murdoch's farm/supply store. I have a couple and this is the bigger one. They've proven to be very useful for firewood, and in the summer they cover up pieces of equipment such as the front hydraulic snow blade to keep the sun off.Is that a Jet Sled? What size is the sled?
