Good afternoon. I am quite interested in this topic since I want to smooth out my yard. I have a L3301 and Land Pride BB1260 box blade. I want to modify the box blade by attaching 3-inch angle iron to the inside with bolts and then weld two pieces of 3 inch angle steel at 10 degree angle. I think that the weight of the box blade will be sufficient and by bolting it to the box blade sides, it will be removable. It will be used to spread municipal compost to smooth out the yard. Any thougths?
Welcome to OTT, HeartFixr!!
Instead of modifying your box blade....maybe a different approach might also be of interest to you.
I used parts off of my box blade to make this
Land Plane. Select that "link" and see Post #6
The three point hitch and both hardened blades were removed and added to the fabricated framework for my land plane. I can unbolt those same pieces and put the box blade back together again when needed.
It was a cheap and easy way to build a land plane that works great. And the box blade can be put back together again if/when needed.
