For the BX22 (2004) Kubota offered a valve and some fancy way to plumb it, but the problems were that the hoses came too close to the cooling fan on the hydro. I found that I could feed the valve with the backhoe lines, and all I had to do to complete the circuit was to add a return from the valve to the side of the hydro unit. It worked well until the valve failed, and I couldn't figure it out, so I removed the cab and the valve, etc., and dropped it off at the Kubota dealer service department telling them that I couldn't get the 3 point hitch to work properly. They tested it and determined that the problem was the pressure, and installed a shim to correct the pressure, and the 3 point hitch was repaired. When I got the tractor back, I reinstalled the cab and the valve and plumbing, only to find that the 3 point hitch stopped working again. Only then did I connect the dots that it was the failure of the valve that was causing me all the problems. I removed the valve and hoses and everything was well again. Had I hooked it up the way that Kubota recommended, it probably wouldn't have affected the 3 point hitch. The lesson that I learned, is that just because you can, doesn't mean that you should. That is why I purchased the LandPride 3rd function valve for my BX23S rather than going the "inexpensive" route as I had done with the BX22.
Part 1 of the saga...
https://www.orangetractortalks.com/forums/threads/3-point-hitch-problem-on-a-bx22.38020/
Part 2 of the saga....
https://www.orangetractortalks.com/forums/threads/rear-remote-valve.43350/
If you are bound and determined to go this route, here is a BX7322 remote kit new in the box for you. The only thing that is missing is the hose kit, which you will not need since the hoses are a lot longer than you will be able to use. Good luck and if you should need some help, I am only a keyboard away. Just hope that you don't ask me the difficult questions, since it was about 15 years ago that I had done this, but I still have the skeletons in the garage. I hate to ever throw anything away. Don't believe me, then ask my wife!
Find many great new & used options and get the best deals for Kubota BX7322 remote valve kit at the best online prices at eBay! Free shipping for many products!
www.ebay.com
