Recently bought an old b7100. Drag link was wasted. Priced one and it was $600. No way!!! Measured stud going in to drag link. 12mm. Ordered 2 tie rod ends. Cut welds on drag link and removed old tie rods. Remember to mark their orientation!!!! New tie rod threaded end fits almost perfectly in the drag link. Measure distance from end of tube to the middle of old tie rod and write it down. Cut new tie rod to measurement of old tie rod end and weld in. You will have to adjust the taper in pitman arm and steering arm ever so slightly with a sander cone in the pics. I have included pics with part numbers. Hope this helps.
