mcmxi
All 11 bolts on my tooth bar lined up perfectly with the holes in the bucket, and the hardware provided was all Grade 8. These are some of the reasons I was happy to pay $160 more for the EA. I'm sure the BX is a good bar too and will serve most users very well.Measure carefully, though, because you get one bolt for each side that's BARELY long enough to start the threads on the nut. If you give them dimensions a little too short, you're gonna have fun getting those bolts put in. I'm probably going to replace the bolts on mine with some Grade 8's about 1/4" longer when/if I take the bar off for any reason.
Look at the difference between the hardware that Kubota uses vs. that provided by EA. Kubota isn't that confident in the bolt on cutting edge lining up with the holes in the bucket but EA nailed all 11 holes. Do you know how hard that is to do?Why,. dealer should have the dimensions of the bucket.If not, call Kubota,they HAVE to have a drawing 'somewhere' witht he dimensions on it....
I can't see how/why the dimns wouild be different within the same series of buckets. After all they gotta FIT the loaders....
Kubota hardware
EA hardware
