Hello all! I just bought a Kubota L225DT the other day. Thought it was cheap enough, but after getting it home the hole started getting deeper. I knew it would need some fixing here and there but never thought I would need a part that is nowhere to be found. The 4WD doesn't work (thought it did) reason is the roll pin had fallen out of the aft spline shaft and was driven like that, which caused the female end of the shaft to just move around and worn all the splines down, male shaft too but that is available. U joints are totally shot,(thought an easy fix) anyway, I cant find the "prop shaft". I have the PN but not available so far. Any advise? have it made? I got screwed on this deal. Thanks, Jim
