Clutch Stuck 2350
jstapler
L245, L3010
Jun 15, 2018
11
covington, Louisiana
The clutch is stuck. The pedal will only move approx. 2" The transmission grinds and will not go into gear while Eng. running. It will go into all gears when eng not running. If in gear and I actuate the starter the tractor will roll and start.
I am told the clutch is stuck to the flywheel. I was advised to fill the gearbox with WD40 or Kerosene and let it sit a few days. Anyone ever try that. I could use any help you can give. Thanks in advance,
John
boz1989
B2910 fel 60 mmm, Land Pride rb1572
Jun 10, 2015
269
Portland, MI
I'm not an expert, but it sounds like you need to split the tractor and at a minimum replace the clutch disk. You would have to inspect the flywheel and pressure plate to see if they will clean up. I would also replace the throw out bearing and pilot bearing while it's apart.
Sent from my LGMP260 using Tapatalk
hodge
Nov 19, 2010
2,882
416
Love, VA
I don't think it has a wet clutch. Putting anything in the gearbox has nothing to do with the clutch. As mentioned, if you can't get it broken free, the tractor will have to be split.
I assume that this is an L2350?
greeno
B2710 w/LA402 FEL, BL4690 hoe, RB1560, GS1560, Haban 5' sickle bar, 5' JD RC
Jul 14, 2018
187
Big Lake MN
My clutch used to stick all the time on my old Iseki. You can try driving it around in high gear and see if it’ll pop free. If you’re real brave drive it into a tree slowly.
4,963
What's the history of the problem? If it's been a few months you may be able to free it up. If you have an open area you could use an implement on the back, like a plow or box blade, have the tractor in the highest gear that will pull it and work the tractor, hoping the clutch comes free.
Yes, as Greeno mentioned, a tree would do the same thing, but you could slide off to a side and cause damage to the metal.
Do not try to add any fluid to the clutch area. It won't stay there if you tried!
SidecarFlip
Banned
554
Why there is a clutch pedal hook on the tractor, any dry clutch needs to be parked DISENGAGED at all times. Any moisture in the bell housing will cause the clutch disc to seize to the flywheel. Draining the bell housing is a good idea too (Kubota provides a drain bolt on the bottom of the bell housing on their tractors, I suggest using it regularly).
I had an old Massey diesel that hung the clutch just like yours has. Start it in high gear pointed toward a tree or some immovable object with the clutch pedal pushed in and pray it breaks free. Mine did and after that I made sure the clutch was disengaged when parked.
Only other option is splitting the unit.
rbargeron
Jul 6, 2015
1,157
227
western ma
The symptom (limited clutch pedal travel) doesn't sound like the clutch disk is stuck to the flywheel - it sounds more like the release bearing and hub are not sliding forward.
If you push harder on the clutch pedal does it return ok? If not, the hub is hanging up. Pushing against a tree won't help.
Some models have bolts or a cover on the housing you might be able to spray some lube through, hoping to free things up in there. If not, the answer may be splitting the machine.
5,047
1,741
you can start out in 1st low easily without the clutch. Shift to 2nd, then one gear at a time, all the way to highest speed, get the RPM up and while the RPM is high in the highest gear/highest range, engine/clutch hot, shove the clutch pedal down and mash the brake pedal. SOMETIMES it'll free up. Other times it won't. If it won't, you'll have to split it & likely replace the disk and pressure plate, also look closely at the flywheel to make sure the surface it clean/rust free/not heat checked.
BTW thanks for reminding me to go hook the pedal down on my little Massey.
SidecarFlip
Banned
554
One worry I don't have with my units. Both have wet packs for clutches. Much preferred for my uses. Hard to beat a hydraulic shuttle.
kubotasam
Apr 26, 2010
1,202
128
Alfred Maine
I agree. If the pedal does not move through its total range of movement it is more than a disk stuck to the flywheel.
rbargeron
Jul 6, 2015
1,157
227
western ma
Of course, we could all be overlooking a simple problem with the pedal linkage. I saw this once when a link eye cracked open, but didn't fail completely. The linkage doesn't travel very far and 1/4" of lost motion can result in exactly the reported symptoms. Maybe we've just blown past the easiest possibility here?
5,712
How would you do that, flip the tractor upside down? :confused:
It can't be done as there is no "fill port" on the clutch housing, only a drain! ;)
Any one that said they have done that is full of it! :p
nezmun
L2350 Kubota Tractor
Aug 13, 2024
10
Washington State
John
I have the same problem with my 2350 Kabota. But my clutch moves the full distance. Yours might be the throw out bearing.
