The clutch is stuck. The pedal will only move approx. 2" The transmission grinds and will not go into gear while Eng. running. It will go into all gears when eng not running. If in gear and I actuate the starter the tractor will roll and start.
I am told the clutch is stuck to the flywheel. I was advised to fill the gearbox with WD40 or Kerosene and let it sit a few days. Anyone ever try that. I could use any help you can give. Thanks in advance,
John
John
